TAIrving Posted October 31, 2023 Report Posted October 31, 2023 Has anyone used this? It is advertised as double-sided woodworking tape. They say it has good holding quality but removes easily from wood, leaving no residue. Sounds interesting. I wonder if we could use it in place of blue painters tape. We could put it on the wood in place of the blue tape, then stick the pattern directly to it with no need for any additional glue. And we could use it to hold pieces together as in stack cutting. I am sure there are / will be many other uses. XFasten Double Sided Woodworking Tape, 1-Inch by 36-Yards, 3-Pack - Double Face Woodworker Turner's Tape for Wood Template, Removable & Residue Free - Amazon.com danny and OCtoolguy 1 1 Quote
barb.j.enders Posted October 31, 2023 Report Posted October 31, 2023 I haven't used that product. I have used this for patterns. Haven't tried it for stack cutting. Don't think it would be strong enough. https://store.workshopsupply.com/catalogue/scroll-saw-stick-and-release-tape-12-20-p-4418.html OCtoolguy and Mark SW 1 1 Quote
Gene Howe Posted October 31, 2023 Report Posted October 31, 2023 I use it to stick wood patterns to wood stock for pattern routing. It holds well for that purpose. It's a bear to remove, though. After you peel off it's protective cover, what's left is the relatively thick adhesive. I have to roll it off the project piece with a thumb. It would be quite expensive to use it to hold paper scroll patterns. And, I'm not sure it wouldn't gum up a scroll saw blade. OCtoolguy and jimmyG 1 1 Quote
Scrappile Posted October 31, 2023 Report Posted October 31, 2023 (edited) There is double sided tape and then there is double sided tape. I have some I purchased to hold a piece of wood to a face plate when turning on a lathe. You could stick to cars together and one could pull the other. I have some double sided carpet tape that is not nearly as strong. I would not use either to hole a paper pattern on but the carpet tape would probably hold pieces of wood together for stack cutting. Edited November 12, 2023 by Scrappile OCtoolguy, JTTHECLOCKMAN and danny 3 Quote
munzieb Posted October 31, 2023 Report Posted October 31, 2023 I have been using 2 sided carpet from Lowes for positioning hinges for alignment and drilling when making boxes, I'll also adhear it the base and top surface edges to sand them flush. I've also used it on small pieces of wood I cut on the table saw to keep my fingers away from the blade. I have also been doing more stack cutting and I use 3M 77 spray glue. I'll spray both sides of printer paper and stick it between the pieces I am cutting and also apply to the bottom of the pattern I am cutting. I was using Goof Off to remove it but it can leave a pink tinge of color on the wood. I have gone to Acetone. I wet a paper towel and dab the pattern and it comes right off (often in one piece) I use an acid brush soaked in acetone and brush along the edges and use a scraper to widen and separate the pieces. I wipe down with acetone to remove any remaining glue and it leaves a clean surface. OCtoolguy 1 Quote
Joe W. Posted November 1, 2023 Report Posted November 1, 2023 10 hours ago, munzieb said: I wipe down with acetone to remove any remaining glue and it leaves a clean surface. Hmmm, I'll have to try that - I've been using MS so far and it does color the wood a little. OCtoolguy and munzieb 2 Quote
Millwab Posted November 1, 2023 Report Posted November 1, 2023 One thing that caught my eye was that the adhesive is "silicone based." Wonder if that would effect finishing the wood it was applied to? OCtoolguy 1 Quote
Gene Howe Posted November 1, 2023 Report Posted November 1, 2023 9 hours ago, Millwab said: One thing that caught my eye was that the adhesive is "silicone based." Wonder if that would effect finishing the wood it was applied to? A good wipe down with Acetone will do the trick. OCtoolguy 1 Quote
Dave Monk Posted November 1, 2023 Report Posted November 1, 2023 I wouldn't be without this double sided tape. https://www.woodworkingshop.com/search/?search_query=double sided tape I use it to hold wood on sanding shims when sanding intarsia pieces. I also use it a lot for holding small pieces on larger pieces when I want to cut them on my band saw. Roberta Moreton and OCtoolguy 1 1 Quote
Roberta Moreton Posted November 3, 2023 Report Posted November 3, 2023 On 11/1/2023 at 7:21 PM, Dave Monk said: I wouldn't be without this double sided tape. https://www.woodworkingshop.com/search/?search_query=double sided tape I use it to hold wood on sanding shims when sanding intarsia pieces. I also use it a lot for holding small pieces on larger pieces when I want to cut them on my band saw. I didn’t realize they carried that. I will try to remember to pick some up! Dave Monk 1 Quote
nrscroller Posted November 12, 2023 Report Posted November 12, 2023 Rockler woodworking also has this for turning purposes Bill Quote
meflick Posted November 14, 2023 Report Posted November 14, 2023 I took Intarsia classes from Judy Gale Roberts. She uses a light duty double sided carpet tape for sanding shims, temporary holds needed so that is what I learned to use. It works well. Any stronger than light duty band it’s hard to get parts back apart. Quote
Roberta Moreton Posted November 15, 2023 Report Posted November 15, 2023 (edited) I believe double stick tape and “Stick and Release” Scroll saw tape, sold by The Wooden Teddy Bear are two different things. Double stick tape is for temporary sticking 2 pieces of wood together and the Scroll Saw tape is for adhering a pattern to the wood. Edited November 15, 2023 by Roberta Moreton Spelling Quote
Denny Knappen Posted November 15, 2023 Report Posted November 15, 2023 I sell ATG tape on the website. We use this every day on our framing projects. I just posted a very short video on using ATG tape. Here is a link to the item. Hand Held ATG Tape | Pegas scroll saw (artcraftersonline.com) Quote
