artisanpirate Posted December 30, 2023 Report Posted December 30, 2023 Rustic Deer Silhouette With Hunting Theme This is a newer Steve Good design. I trimmed the pattern out and attached it to my material with clear packing tape (clear packing tape helps lubricate the blade and reduce burn marks) The main scroll work is 1/4 inch material and the backer board that includes the antlers is 1/2 inch material. I drilled all of my pilot holes with my amazing @seycoscrollsaw Scrollers drill I then cut everything out on my @deltamachinery scroll saw with number 5 ultra reverse tooth blades (scrolling took around an hour as I was also messing with the laser) After the pieces were cut, I removed the waste and sanded both the front and back of the pieces with 180 @klingsporswoodworkingshop sandpaper in my vibrating palm sander (an orbital sander would be too aggressive to sand scroll work) Then it was time for staining, and I used a light @minwaxusa stain and a darker stain to add some color difference. After that dried, I glued the pieces together with Medium Grade CA Glue. And after that dried, I gave the piece several coats of @rustoleum clear gloss for a finish and protection. I made this for a good friend who is an avid outdoorsman. Great way to spend a morning in the workshop. . . #ArtisanPirate Roberta Moreton, ChelCass, BadBob and 4 others 7 Quote
Peter N White Posted December 30, 2023 Report Posted December 30, 2023 Great work. Looks really good. artisanpirate 1 Quote
rjweb Posted December 31, 2023 Report Posted December 31, 2023 Really nice design and cutting, RJ artisanpirate 1 Quote
