Popular Post Wichman Posted January 6, 2024 Popular Post Report Posted January 6, 2024 (edited) This is a Steve Good pattern. The original was somewhat larger ( 7 inches ), but I need to use up some 3 1/2" cork coasters I have. So, I reduced the pattern until it just fit within the 3 1/2" coaster. I cut the inside of the pattern, then laminated the wood to the cork, and after the glue (polyurethane, 100% waterproof) cured I cut the outside. Everything worked like a charm, very pleased with the result ( many, many times it just doesn't work the way I want and I have to make adjustments). 1/4 inch Elm, 1/8 inch cork, FD Polar #1 for the inside, #3 for the outside. Edited January 6, 2024 by Wichman TAIrving, Dan, barb.j.enders and 15 others 18 Quote
Scrappile Posted January 6, 2024 Report Posted January 6, 2024 that is a real nice looking coaster. Quote
heppnerguy Posted January 6, 2024 Report Posted January 6, 2024 A coaster that will stand out and cause a lot of nice comments instantly. I bet you will receive several hints of maybe making one or two for them also Dick heppnerguy Quote
