My Dewalt DW788 air nozzle is cracked right where it snaps onto the saw. So it isn't tight and just kinda flops about. I am here at work and was about to order a new nozzle but started thinking... Can I just remove the broken section on the end of the hose and snap the next section onto the saw? Is it the same size?
18 minutes ago, Denny Knappen said:
I have not done that, but I heard that you could.  Use a hair dryer to softened the plastic, remove the cracked one and install the next one.  The only problem is it shortens the reach.
Thanks Denny, it would shorten it slightly but I personally think it's too long anyway. I think I'm going to try it tonight before I spend $$. What's the worst that can happen, I break it? haha.
Yes, you can remove the broken piece and a hair dryer is a good method to soften the links (if you don't overheat them) for removal and replacement. You can get more links as spares from DeWalt or parts distributors like www.ereplacementparts.com, or from a local industrial supply like Grainger, McMaster Supply, etc. Even Amazon offers them.
Charley
Yeah I had to do that several times on my old Dewalt when i had it.. was getting to a point where it was starting to get kind of short when i sold the saw. LOL
I found that the thing kept breaking because it was so long to begin with and I was always fussing with it to adjust it. It would get stiff to move too and finally break. I found if i put some dry lube on the nub where it attaches it would move more freely and I wouldn't keep breaking it.
They come apart kind of hard.. and go back on even harder, LOL.. I found heating it in some hot water or a heat gun and a little dab of soap helps it go back on easier..
Edited by kmmcrafts
