Popular Post Foxfold Posted January 20, 2024 Popular Post Report Posted January 20, 2024 (edited) Decided to try cutting acrylic and it worked out well. Although this was 3mm, A4 sheet of acrylic but it felt like cutting 6mm, you had to let the blade do the work. I used a #3 Niqua blade and had no problems with any melting that I had anticipated. So all in all quite a good experience. Not easy to photograph though as it's so reflective. Edited January 20, 2024 by Foxfold MarieC, danny, Charlie E and 16 others 19 Quote
Ron Johnson Posted January 20, 2024 Report Posted January 20, 2024 That turned out really well Brenda. Foxfold and danny 1 1 Quote
Denny Knappen Posted January 20, 2024 Report Posted January 20, 2024 Very well done. When I cut acrylic, I used a Pegas #3 Supper Skip blade. Foxfold 1 Quote
meflick Posted January 21, 2024 Report Posted January 21, 2024 Nice job Brenda. The only time I cut acrylic, it was for oval blanks for a “doggie bank” I made a great niece a couple years ago. No where near as detailed as your handsome dog here. Foxfold 1 Quote
barb.j.enders Posted January 21, 2024 Report Posted January 21, 2024 Great cutting. Looks awesome Foxfold 1 Quote
goldfish Posted January 21, 2024 Report Posted January 21, 2024 I find it you put masking tape on the front and back of the sheet it helps to stop the melting effect. Foxfold 1 Quote
MarieC Posted January 21, 2024 Report Posted January 21, 2024 Brenda, Really nice work. Are you going to put a backer on it, if so what type, or something else like hang it in a window? Quote
Foxfold Posted January 21, 2024 Author Report Posted January 21, 2024 4 hours ago, goldfish said: I find it you put masking tape on the front and back of the sheet it helps to stop the melting effect. This had some kind of plastic film on both sides so I'm presuming that is what helped with the cutting Quote
Foxfold Posted January 21, 2024 Author Report Posted January 21, 2024 (edited) 21 minutes ago, MarieC said: Brenda, Really nice work. Are you going to put a backer on it, if so what type, or something else like hang it in a window? It's going as it is onto my wall in the house. As my walls are 'cream' I find I quite like the effect. Haven't got a photo of it on the wall but here's one I cut out of wood that's already up. Edited January 21, 2024 by Foxfold Scrappile and MarieC 2 Quote
Scrappile Posted January 21, 2024 Report Posted January 21, 2024 That is a wonderful cutting. Your dogs are so beautiful! Foxfold 1 Quote
wombatie Posted January 22, 2024 Report Posted January 22, 2024 It looks great. It's good to experiment with different materials, isn't it? Marg Foxfold 1 Quote
Mark SW Posted January 23, 2024 Report Posted January 23, 2024 Nicely done Brenda. So how would you hang that? You would need a frame, yes? Or could you use eye hooks on the top? Quote
Foxfold Posted January 24, 2024 Author Report Posted January 24, 2024 14 hours ago, Mark SW said: Nicely done Brenda. So how would you hang that? You would need a frame, yes? Or could you use eye hooks on the top? No, I will use adhesive strips, they are very effective. I hang all my pictures with them 'Command Strips' Mark SW 1 Quote
Hudson River Rick Posted January 24, 2024 Report Posted January 24, 2024 Very nice job on cutting the acrylic, and a really nice pattern of a beautiful dog. Rick Foxfold 1 Quote
rdatelle Posted January 24, 2024 Report Posted January 24, 2024 WoW Brenda, that came out great. Foxfold 1 Quote
