Hawk Posted February 6, 2024 Report Posted February 6, 2024 I'm trying to upgrade/replace the dust blower on my Delta P-20 with Loc-Line. The original one broke at the entry point on the upper arm. I need to find a nut to go on the Loc-Line connector, the size I need is 10mm with a pitch of 1.0, I've been searching hardware stores, online and I find plenty of 10mm with a pitch of 1.5 Any idea where I could fine a nut to fit the part in the picture? the smaller one is what fit the hole for the blower line. Hope this wasn't too confusing. Thanks, Chris Quote
Ctutor Posted February 6, 2024 Report Posted February 6, 2024 are you sure you need a nut. Could you use heat shrink tubing on the fitting that is left Quote
Hawk Posted February 6, 2024 Author Report Posted February 6, 2024 (edited) The fitting fits through a hole in the side of the upper arm. Shrink tubing may work, I'll keep that in mind. Edited February 6, 2024 by Hawk Quote
kmmcrafts Posted February 7, 2024 Report Posted February 7, 2024 (edited) I don't know what size these are in this kit but it shows two different threaded parts and one looks a lot like what you show here. I've bought pieces and parts of this stuff from here before so maybe do some looking. Also known as coolant hose for metal drills/lathes etc. so that might be another search term to use. https://www.grainger.com/product/6Y724?gucid=N:N:PS:Paid:GGL:CSM-2293:99F1R6:20501231&gad_source=1&gclid=Cj0KCQiAzoeuBhDqARIsAMdH14Ghe-brxtcqgwme5esjlHRkXt5xcAAFkvjYVd-ihU4pm762EcEcRssaAis8EALw_wcB&gclsrc=aw.ds Edit Oopps I guess I should have read better. Looks like you've already searched the parts but cannot find exact thread size. Edited February 7, 2024 by kmmcrafts Quote
Hawk Posted February 7, 2024 Author Report Posted February 7, 2024 I'm thinking that I may need to improvise and adapt something, I can find something that looks like it may work on the Loc Line site, but the description isn't the best, and buying 20 of them to get it wrong doesn't make since. The search continues.................... Quote
Angelo Posted February 7, 2024 Report Posted February 7, 2024 Hi, you should try McMaster-Carr , in their website you'll find any kind of nuts …..they are not cheap but you’ll find what you need. Kind regards Angelo Hawk 1 Quote
OCtoolguy Posted February 7, 2024 Report Posted February 7, 2024 8 hours ago, Hawk said: I'm trying to upgrade/replace the dust blower on my Delta P-20 with Loc-Line. The original one broke at the entry point on the upper arm. I need to find a nut to go on the Loc-Line connector, the size I need is 10mm with a pitch of 1.0, I've been searching hardware stores, online and I find plenty of 10mm with a pitch of 1.5 Any idea where I could fine a nut to fit the part in the picture? the smaller one is what fit the hole for the blower line. Hope this wasn't too confusing. Thanks, Chris Those are pipe threads. Not metric. Quote
kmmcrafts Posted February 7, 2024 Report Posted February 7, 2024 7 hours ago, OCtoolguy said: Those are pipe threads. Not metric. Kind of what I was thinking too. Also I’m quite sure loc line has adapters to go from metal tubing to their plastic fittings. They are pretty versatile. Somewhere ( maybe eBay) I’ve seen these fittings sold individually. Quote
Scrappile Posted February 7, 2024 Report Posted February 7, 2024 That is a loc-line product. You might contact them here and ask. I have purchased directly from them before: https://www.loc-line.com OCtoolguy 1 Quote
OCtoolguy Posted February 7, 2024 Report Posted February 7, 2024 Here is where I have purchased all my Loc-Line stuff. https://www.modularhose.com Quote
rash_powder Posted February 7, 2024 Report Posted February 7, 2024 Hot glue works great. It will come off too, just takes a little work. OCtoolguy 1 Quote
rafairchild2 Posted February 8, 2024 Report Posted February 8, 2024 RTV Silicone works well too. https://amzn.to/3uqeYaO OCtoolguy and Hawk 2 Quote
Hawk Posted February 11, 2024 Author Report Posted February 11, 2024 Well, what I did was fashion a nut out of yellow heart and along with some Goop glued the assembly into the P20. Trying to get that "nut" on then the hose put thru it under that arm was not easy for this guy. But it works and that what counts. I really like my P20, it's just so dang heavy (lol) Thanks for all the suggestions. Chris OCtoolguy 1 Quote
