Popular Post Wichman Posted February 11, 2024 Popular Post Report Posted February 11, 2024 Just finished this one. Idaho plaque, pattern by BoB scroll . Wood is a repurposed plaque ( 6" X 23" ) from a thrift store, 3/4 pine; blades FD Polar #1 throughout. Second Picture is the piece on the saw with a " 1 2 3 block" as a counterweight, nonslip pad underneath. Started cutting in the center to reduce the weight when I got to the ends. munzieb, MarieC, red river and 17 others 18 2 Quote
FrankEV Posted February 11, 2024 Report Posted February 11, 2024 Very nice cutting. Counterweight a great idea. What are your plans for a backer and finish? Wichman 1 Quote
preprius Posted February 11, 2024 Report Posted February 11, 2024 looks nice and clean. The wood knots resemble potatos. One tractor is running over one. Wichman 1 Quote
Wichman Posted February 11, 2024 Author Report Posted February 11, 2024 3 hours ago, FrankEV said: Very nice cutting. Counterweight a great idea. What are your plans for a backer and finish? I haven't decided on a backer yet. The piece is prefinished with a cream paint ( that was part of the test, paint stayed put and did not splinter at all ) The plaque is really off balance, the knots are much heavier than the rest of the wood. I'm thinking of using a couple of small screws and a cord, maybe shifting the attachment points towards the weighted side. Quote
Ron Johnson Posted February 11, 2024 Report Posted February 11, 2024 Very fine plaque. Wichman 1 Quote
Wichman Posted February 11, 2024 Author Report Posted February 11, 2024 8 hours ago, FrankEV said: Very nice cutting. Counterweight a great idea. What are your plans for a backer and finish? Been thinking about this one. 1/8 hardboard backer just over the size of the plaque, this will present some issues because that's larger then the throat of the saw, I can cut half from each direction though. I was thinking of painter the backer the colors of the Idaho License Plat; Red on top, a band of white in the middle, and blue on the bottom. If I use the tractor cut outs as plugs, I can use countersunk screws to mount the piece and eliminate tipping (the piece is out of balance. I'm thinking of adding shaker pegs on each end to make the piece more functional. danny 1 Quote
FrankEV Posted February 11, 2024 Report Posted February 11, 2024 2 hours ago, Wichman said: Been thinking about this one. 1/8 hardboard backer just over the size of the plaque, this will present some issues because that's larger then the throat of the saw, I can cut half from each direction though. I was thinking of painter the backer the colors of the Idaho License Plat; Red on top, a band of white in the middle, and blue on the bottom. If I use the tractor cut outs as plugs, I can use countersunk screws to mount the piece and eliminate tipping (the piece is out of balance. I'm thinking of adding shaker pegs on each end to make the piece more functional. You could use the plaque as a template and trim the backer with a router with a trim bit. However, because the Plaque is pre painted, I might be inclined to make the backer smaller than the Plaque so the backer edges do not show when hung. To hang I would install two sawtooth hangers, one near each end close to the top. It will hang with out any tipping. Adding shaker pegs would be a nice touch, but not sure what would get hung on them. IMO, jackets or the like would be too heavy. Small fancy hooks might be better for hanging Keys or such. The backer colors sound good, just wondering if they will show enough. Potatoes are brown, aren't they. A simple dark brown might look nice also. These are all just my thoughts. Not trying to tell you what to do. preprius and Wichman 1 1 Quote
Denny Knappen Posted February 12, 2024 Report Posted February 12, 2024 Nice clean lines. Wonderful plaque. Wichman 1 Quote
heppnerguy Posted February 15, 2024 Report Posted February 15, 2024 another thought for hanging that can work is to use a toothed oblong hanger and then old the plaque between your thumb and index finger and bring the piece down to a table or flat surface, watching which side hits the table first. They move your hold toward that side and test it again. Do this until you find that the entire projects tough the surface at the same time. marking where you are holding the back side at that point, hammer in the saw tooth mounting bracket in the middle of where you were holding it when it hit the surface evenly. It does not matter if it is not exactly in the middle of your piece as it is not seen once it is hung and you can easily make small adjustment by simply moving it in the mounting bracket as needed. Dick heppnerguy Wichman 1 Quote
MarieC Posted February 16, 2024 Report Posted February 16, 2024 Very nice! I miss Idaho....graduated from Coeur d'Alene HS and North Idaho College. Really nice work. And your idea for using a counter weight is an excellent idea. I will be using that on my current project as well. Thanks for the idea! Marie Wichman 1 Quote
wombatie Posted February 16, 2024 Report Posted February 16, 2024 Looks terrific. Clean and crisp, the cutting not the potatoes. Marg Wichman 1 Quote
bobscroll Posted February 17, 2024 Report Posted February 17, 2024 Well done! It looks real nice to look at, Thank you for posting, Bob danny and Wichman 1 1 Quote
