Popular Post FrankEV Posted February 22, 2024 Popular Post Report Posted February 22, 2024 I developed this Roaring Bear Pattern from an Image I found on-line. I invite you to visit my post in Pattern Making for a description of my experiment in creating this pattern. Also, you will note that my pattern is kind of backwards to the way most patterns result in creating a scrolled image. Since the bear is predominately Black, the cut-outs exposing the background are light colors as if sunlight was reflecting off the Bear’s fur. The pattern was sized to fit a 12” by 12” inch panel. I chose to cut the image in a 5/32” thick Walnut Solid Core Ply using Pegas #2/0 Spiral blades. The backer is 1/4” thick BB Ply. Most of the coloring was done with Artist Acrylic Air Brush Paints with a few highlights done by brush. The assembled panel was protected with multiple spray coats of a Clear Gloss Acrylic. I made my usual 1 3/4” wide rail Poplar Frame that I stained and finished with multiple coats of Wipe-On Poly. I ‘m looking forward to your comments and critiques on this experiment in pattern making and my…possibly poor…choice of using Walnut for the cut panel. Dak0ta52, jr42, meflick and 9 others 12 Quote
rjweb Posted February 23, 2024 Report Posted February 23, 2024 Nice, looks like he is made about something, RJ FrankEV 1 Quote
MarieC Posted February 24, 2024 Report Posted February 24, 2024 I love your bear ....As you mentioned, I am not sure about the background either. Perhaps the grain of the frame and the grain of the background are distracting me...not sure. Maybe more of a lighter boring colored background. Here is a painting of a horse that I thought looked good with the background. If you had a bigger background, and since you airbrush very well, you could do a moon so that is what is lighting his fir like this picture I found on etsy but maybe you don't really want the silhouette look... Not sure if this helps. marie Roberta Moreton and FrankEV 1 1 Quote
Peter N White Posted February 24, 2024 Report Posted February 24, 2024 Great job looks really good. FrankEV 1 Quote
