Popular Post red river Posted March 21, 2024 Popular Post Report Posted March 21, 2024 A big thanks to Bobscroll for these patterns, which I got from the Scroll Saw Village library. All done on 1/4 in BB ply. When the morning sun hits them they really sparkle. I can't seem to catch it on my cell phone camera. I hope I submitted this right...I'm still learning the system. MarieC, jr42, keefie and 18 others 21 Quote
TAIrving Posted March 22, 2024 Report Posted March 22, 2024 Very nice Forrest! I enjoy working with epoxy fill in my scroll saw projects and I understand the challenges of doing multiple colors in one piece. Regarding the pictures, it would be nice to be able to see the wood also. You might be pushing the capabilities of your cell telephone camera in trying to capture the bright glow of the sun shining through the colored fills. Quote
Scrappile Posted March 22, 2024 Report Posted March 22, 2024 Those are real pretty! Must try sometime. Quote
Denny Knappen Posted March 22, 2024 Report Posted March 22, 2024 The use of epoxy resins is a step up. Something I want to try in the near future. Quote
red river Posted March 28, 2024 Author Report Posted March 28, 2024 Thanx for the compliments..... Quote
heppnerguy Posted April 2, 2024 Report Posted April 2, 2024 They sure pop with that epoxy. Still have not taken the jump into trying it, myself. Looks great Dick heppnerguy Quote
Bill WIlson Posted April 3, 2024 Report Posted April 3, 2024 I'm dipping my toe into using colored epoxy casting resin. Picked up some at Michaels for a project I'm working on for my daughter. It isn't a scroll saw project, but rather a simple bench. I want to rout the letter D into the top and fill it with epoxy. I've used 5 minute epoxy to fill small knot holes before, but never used epoxy for decorative effect. I made a test piece, because I had several questions regarding its use. The project is made of red oak, which has a very open grain. I was concerned that the dyed resin overflow would seep too deeply into the pores of the wood to be effectively removed by sanding the resin flush with the surface. That proved to be less of a problem than I had imagined. Next question was would the area around the epoxy inset take stain similar to the rest of the surface or would there be a noticeable halo around where the stain couldn't penetrate as well, due to the overflow of the epoxy that I ended up sanding off. That too proved not to be a problem. My next step is to see if it will accept a topcoat. After some internet searching, I've read mixed reviews of applying a polyurethane topcoat over epoxy. Most said it worked fine. Others said it didn't. I'm going to apply a seal coat of shellac first, then a topcoat on my test piece to see how it goes. The biggest challenge I've had so far is controlling the overflow of the epoxy. Once it flooded the banks of the routed inset, it kind of ran wild on me. I over did it by pouring too much and once it started overflowing, trying to scrape it back into place and remove the excess just created more of a mess. I definitely need a little practice with this part. I'm going to try it on a 2nd test piece, but I've applied clear packing tape over the area of the inset. I then routed the area and have applied a bead of hot glue around the perimeter to control any overflow and keep it from spreading too far. I hope to test this in the next couple days. For those of you who are more experienced with this process, do you have any tips & tricks to offer to a newbie? Quote
scrollerpete Posted April 3, 2024 Report Posted April 3, 2024 (edited) To control any overflow I use clear Silicone caulking, it works great and to remove just use a chisel and than sander Edited April 3, 2024 by scrollerpete Quote
rdatelle Posted April 4, 2024 Report Posted April 4, 2024 Those look great. Never used resin. Wouldn't know where to start. Quote
