8 hours ago, rdv464 said:
Has any one replaced the upper & lower arm bearings RBI G4
I have not seen much on any bearing replacement on the Hawks other than the arm that connects the lower arm down to the motor.. I have done that on one of my saws and have seen topics where others have also done that. Never seen anything on the arm bearings though.
What kind of questions do you have about the arm bearings? I've had the arms off of a couple of my Hawks but they were older saws that had a different style bearing than these newer saws.. but maybe I can answer if you have a specific question about them.
I've replaced bearings on most of my G4, but not those.  However, that entire saw is easy to work on, so I doubt you will have much of an issue replacing them.  Being an owner of a G4, and a person who restores machinery, I can try to answer any questions, or even take my saw apart, should the need arise.
Dan
