edward Posted April 28, 2024 Report Posted April 28, 2024 Does anyone use 1/4" basswood for their projects instead of 1/4" Baltic Birch, if so is it good to work with, thanks for any info. OCtoolguy 1 Quote
Wichman Posted April 28, 2024 Report Posted April 28, 2024 These are ornaments cut from 1/8" basswood (hobby lobby) it cuts well and as you can see, will take details without falling apart. Gene Howe, OCtoolguy, Dave Monk and 1 other 2 1 1 Quote
jimmyG Posted April 29, 2024 Report Posted April 29, 2024 15 hours ago, edward said: Does anyone use 1/4" basswood for their projects instead of 1/4" Baltic Birch, if so is it good to work with, thanks for any info. Use it 1/8 up to 3/4 and get clean easy cuts. Quote
Norm Fengstad Posted April 29, 2024 Report Posted April 29, 2024 I use basswood mostly for carving as it is softer wood and cuts easily with a sharp carving tool., It also cuts very good on a scroll saw. since it is close a grained wood it is quite strong and takes paint and clear finish very well. If there is a down side to Bass wood that would be not much grain to it. Baltic birch would be a bit stronger and less prone to breaking. JTTHECLOCKMAN 1 Quote
Denny Knappen Posted April 29, 2024 Report Posted April 29, 2024 I find that Basswood leaves a lot of fuzzies. jimmyG 1 Quote
