Why didn't I think of this sooner.
I sand a lot of small parts and it has always been a pain trying to hold them in place.  Today a lightbulb turned on. Hard to believe with this old brain.  I took a piece of 1/2" plywood and put shelf paper on it. I then used spay glue on the back of a sheet of 120 grit sandpaper and stuck it to it. Worked great! I'm sure I'm not the first to come up with this solution but I thought I might share it.
I have two 10" steel sanding disks ( for the table saw ) and I can put different grits on each side, so up to 4 different grits.
I removed the platen for a 6 inch disk sander and have several different grits of PSA disks, I have drilled a hole in my workbench ( next to the scroll saw ) that the platen will fit in so that the workbench supports the platen.
