Popular Post FrankEV Posted July 19, 2024 Popular Post Report Posted July 19, 2024 This is only my second Intarsia piece, and yes again, it is almost a direct copy of a work I found on-line. For a full descriptive write up see my post in the Intarsia/Segmentation section. Thanks for reading. BadBob, JJB, Matt B and 9 others 12 Quote
rjweb Posted July 19, 2024 Report Posted July 19, 2024 Frank, excellent craftsmanship, RJ FrankEV 1 Quote
heppnerguy Posted July 19, 2024 Report Posted July 19, 2024 Very nicely done Frank. I enjoy seeing your posts as I know they will be well worth checking out and I am always rewarded for my time to check them out. Dick heppnerguy FrankEV and barb.j.enders 1 1 Quote
Dave Monk Posted July 19, 2024 Report Posted July 19, 2024 6 hours ago, FrankEV said: This is only my second Intarsia piece, and yes again, it is almost a direct copy of a work I found on-line. For a full descriptive write up see my post in the Intarsia/Segmentation section. Thanks for reading. Steve good has a rose segmented pattern that is super for intarsia. It is called Segmented Rose. Nice work. WARNING.............Intarsia is addictive. FrankEV 1 Quote
FrankEV Posted July 20, 2024 Author Report Posted July 20, 2024 (edited) 53 minutes ago, Dave Monk said: WARNING.............Intarsia is addictive. On these first two attemps I found the Scroll Saw cutting to be easy-peasy. The shaping work takes much more time to do well. Working with the very small pieces. like the thorns on the Rose stem, is a stiff PITA. Also, being able to visulize the image is very important. I can also see where, if trying to be true to an image, wood color choices can be daunting. Yes, it is more relaxing than cutting a 700 hole Art panel and I don't have to make a frame to mount the panel into. However, I don't get to use my Air Brush to add color, which is a skill I'm trying to improve on. Not too sure if I will get addicted to doing Intarsia, but I can see developng some of my own patterns and doing the work along with my other work. I do need a break now and then from the Art Panel work that I do. BTW I'm curious, if you were to do this piece, what would your wood choices be? Edited July 20, 2024 by FrankEV MarieC 1 Quote
Dave Monk Posted July 20, 2024 Report Posted July 20, 2024 (edited) 2 hours ago, FrankEV said: On these first two attemps I found the Scroll Saw cutting to be easy-peasy. The shaping work takes much more time to do well. Working with the very small pieces. like the thorns on the Rose stem, is a stiff PITA. Also, being able to visulize the image is very important. I can also see where, if trying to be true to an image, wood color choices can be daunting. Yes, it is more relaxing than cutting a 700 hole Art panel and I don't have to make a frame to mount the panel into. However, I don't get to use my Air Brush to add color, which is a skill I'm trying to improve on. Not too sure if I will get addicted to doing Intarsia, but I can see developng some of my own patterns and doing the work along with my other work. I do need a break now and then from the Art Panel work that I do. BTW I'm curious, if you were to do this piece, what would your wood choices be? I think your wood choices were good. I have done roses in Cedar, aspen, canary and padauk. There are lots of different color roses. Edited July 20, 2024 by Dave Monk MarieC, FrankEV and barb.j.enders 3 Quote
wombatie Posted July 22, 2024 Report Posted July 22, 2024 You are doing great Frank, keep it up. Marg FrankEV 1 Quote
