preprius Posted July 22, 2024 Report Posted July 22, 2024 Hi villagers... I finally decided to do something. But I ran into some small hurdles. Those hurdles were really small because I remembered some tips I read in the village. I wanted to make a joint that slides into another wood. This one is is at 45deg. So I remember someone saying single bevel cut, you can only do with spiral. So you cut without spinning the wood. Using all sides of the spiral blade. Here is the fit check. It is too tight need to sand it. Here is my scrollsaw sander / file. The other tip was great , another piece of this project was longer than my 26" C arm . . So I remember to turn the blade so it cuts backwards. No picture. But a great tip. So it was a simple project but I am not done. A simple towel rack. But it won't be holding towels. I had to do a size check before I continue. Actual placement on the wall. I have to shape the corners and decide what fretwork to add. Suggestion for fretwork are welcome. OCtoolguy, jollyred, JackJones and 1 other 3 1 Quote
