I am attempting to use Gallery Glass to make sun catchers out of 1/8 plywood. Do you fill in the entire depth or just a covering? I filled the depth and have found out that the sun does not shine through the product. Also how long do I need to let it dry? Any suggestions will be appreciated.
Don't know as I have never used it, but based on what I have read it would look like it can take 8-12 hours to dry and it looks like it is suppose to be thin covering. So maybe 1/8" is to thick?? Let us know what you find out.
Thick Gallery Glass does not completely dry to a brittle state. It remains rubbery. It does turn transluceint and allows light to illuminate it and it takes approx 72 hours to get into this state. You must ensure that your piece is clamped firmly on a wood backing covered with Saran Wrap as it will leak through the bottom and smear the bottom of the item. Overall, happy with results from this learning experience.
