Denny Knappen Posted August 19, 2024 Report Posted August 19, 2024 Alex Fox Basket C03 Modified, I only cut 7 rings making the basket 2" high. I used 1/4" solid Cherry 8" square. Cut on the Pegas Scroll Saw using Pegas #1 MGT blades. After sanding and gluing each ring, I sprayed with two coats Lacquer Clear Gloss, Light sanding after each coat. Comments welcome. rhw, RabidAlien, FrankEV and 4 others 6 1 Quote
FrankEV Posted August 19, 2024 Report Posted August 19, 2024 Beautiful! A lot of small contact points between rings. What glue did you use? How did you aplly and clamp? Quote
Denny Knappen Posted August 19, 2024 Author Report Posted August 19, 2024 36 minutes ago, FrankEV said: Beautiful! A lot of small contact points between rings. What glue did you use? How did you aplly and clamp? Thanks Frank. I use Titebond11 applied with a very tiny brush (about 5 bristles). I use two bricks as weight. BadBob and FrankEV 1 1 Quote
Denny Knappen Posted August 20, 2024 Author Report Posted August 20, 2024 17 hours ago, rjweb said: Denny, very nicely done, RJ Thanks, RJ. Quote
Denny Knappen Posted August 20, 2024 Author Report Posted August 20, 2024 1 hour ago, daveww1 said: excellent job Thanks, Dave. Quote
alexfox Posted August 20, 2024 Report Posted August 20, 2024 I like this way of finishing, looks great! Quote
Denny Knappen Posted August 20, 2024 Author Report Posted August 20, 2024 1 hour ago, alexfox said: I like this way of finishing, looks great! Thanks Alex and less rings to cut! Quote
