Popular Post Lester Willerton Posted August 31, 2024 Popular Post Report Posted August 31, 2024 I completed this Sleigh Ride. Pattern by Charles Hand. I stacked three layers 1/8 Baltic birch covered in green painters tape. Pattern attached with 3M77 spray. Cut with Pegas #2/0 and #0 and #1 spiral blades. Slow going. 13 hours seat time. Cut on my King Industrial 21 inch saw. My first project completed with spiral blades. It was a learning curve but I will use them again on similiar patterns. After getting rid of as many fuzzies as I could and sanding I sprayed with laquer. The one in the grey frame will go to a friend who took my wife and I and our kids and grandkids on sleigh rides through the forest on his property a couple times. Grandkids still talk about those rides. When I saw the pattern by Charles Hand in Scrollsaw Woodworking magazine issue 89 I knew right away I wanted to cut it for Al as a thank you. JackJones, Dak0ta52, GPscroller and 11 others 13 1 Quote
Peter N White Posted August 31, 2024 Report Posted August 31, 2024 Great pattern and equally great cutting. Quote
rdatelle Posted August 31, 2024 Report Posted August 31, 2024 Wow! That came out beautiful. I can see all the work you put into that. Great detail. Quote
scrollerpete Posted August 31, 2024 Report Posted August 31, 2024 I understand the work involved because I cut this pattern also but with straight blades, you did an excellent job. Quote
Lester Willerton Posted September 1, 2024 Author Report Posted September 1, 2024 Thanks for the kind comments. It was fun to cut and I enjoyed the spiral blades and not have to be spinning the 11x14 workpiece when using straight blades. I will use them again but will still use straight blades on many projects as well. Quote
GPscroller Posted September 1, 2024 Report Posted September 1, 2024 Great cutting on a super pattern. I cut same pattern several years ago back in the old days when I only used straight blades. Jeff Quote
rjweb Posted September 1, 2024 Report Posted September 1, 2024 Beautiful piece, excellent cutting, RJ Quote
