I am working on a custom order for some Christmas ornaments. They want them made from hickory. I know it is tough and very strong, but I have never cut any with a scroll saw or any saw.
Do you have any experience with hickory?
Hickory has a Janka of ~1820, this is the same as Yellow Heart.  If you are cutting 3/4 inch thick it is doable, but you'll be slow going and burning through blades.  If you are doing 1/8 - 1/4 you'll have less surface friction so it won't be too bad.  Blades won't last as long as say basswood or soft maple, but you should be fine.
ETA: Purpleheart is 2520, bloodwood is 2900.  I did a 1/2 inch (heart) piece in BW, and although I went through a lot of blades I did not have issues. Hickory at 1/2" or less will be easy.
Edited by rafairchild2
What kind of blade did you use for bloodwood?
In the case of the one I pictured above, I used a #5 Flying Dutchman Ultra reverse for the large cuts on the left and middle.  A #3 for the smaller detailed work on the right, and a #7 for the perimeter.
Since I was burning out blades after about 15-20 minutes, using the various sizes was helpful for me.
9 hours ago, OCtoolguy said:
Does bloodwood stay that color or does it turn dark like padauk? I'm very disappointed in the projects I've made using padauk.
A lot can help them from changing color tones can be done by the type of finish you apply. I don't personally know of a wood that doesn't change color tone some if it's in the sunlight at all. A quality topcoat finish with UV protectant will go a long way farther than cheaper rattle can finishes and oil finishes. I don't really know of a good wood clear coats but I know some high end woodworkers that use automotive urethane clear.. which I think is probably about as good as it gets. Not cheap though.
