Hudson River Rick Posted October 29, 2024 Report Posted October 29, 2024 Can someone please help me with my Pegas Blade holder problem ? I just ordered the replacement spring for the tension lever from Denny, and I have removed the lever, but I am not sure if the post that is under the lever should also be removed. As you can see from the picture, the spring is below the post, I don’t think that tension would be applied to the lever in that configuration. Thanks in advance for any help. OCtoolguy 1 Quote
kmmcrafts Posted October 30, 2024 Report Posted October 30, 2024 Hmm, I've never really looked over my clamps or how they are assembled or work, I know they have parts for these but I've never had to replace anything yet. I do keep mine lubed good with some dry spray lube so they're always working as smoothly as possible to hopefully prevent me from having to replace any parts. I've seen where many folks have talked about replacing this spring but I never knew why it needed replaced. I know a within the first year it seemed like the moving parts were not working as smoothly as they originally did so that is when the use of the dry spray lube came into play for me. If nobody has answered your questions I'll try to take a look at my clamps tomorrow and see if I can understand how this is assembled and maybe I'll be able to help answer your question. OCtoolguy 1 Quote
kmmcrafts Posted October 30, 2024 Report Posted October 30, 2024 I’m not sure I’m understanding your question so I just took a couple pictures of my clamp in case it might help you. From what I can tell it looks like the spring just sets in that slot and the rod goes through it. Not sure if that’s what you’re asking though. One photo with lever in the released position and the other in a tension position. Quote
OCtoolguy Posted October 30, 2024 Report Posted October 30, 2024 The spring is only there to apply return tension to the lever. Blade tension is applied through the cam action of the lever. Quote
dgman Posted October 30, 2024 Report Posted October 30, 2024 20 hours ago, Hudson River Rick said: Can someone please help me with my Pegas Blade holder problem ? I just ordered the replacement spring for the tension lever from Denny, and I have removed the lever, but I am not sure if the post that is under the lever should also be removed. As you can see from the picture, the spring is below the post, I don’t think that tension would be applied to the lever in that configuration. Thanks in advance for any help. Question, why do you want to replace the spring? It is only there to apply tension to the lever. If the lever is popping out of tension, the lever needs to be replaced. It is a common replaceable item. OCtoolguy 1 Quote
Hudson River Rick Posted October 30, 2024 Author Report Posted October 30, 2024 @kmmcrafts Thanks for your reply Kevin. I know now that I should have asked how to remove the podt so I could insert the new spring. When I tried to remove the post, there was a good amount of resistance, and I'm not sure if it is a press fit or are ther threads on the rod? @OCtoolguyThank you. Please see my reply to Kevin @dgman Thank you for your resonse. Please see my reply to Kevin OCtoolguy 1 Quote
Denny Knappen Posted October 30, 2024 Report Posted October 30, 2024 I gave you a reply to your post on another forum. The post should not be removed. The spring fits around the post. The tension lever rides on the post when you apply tension. OCtoolguy 1 Quote
kmmcrafts Posted October 30, 2024 Report Posted October 30, 2024 43 minutes ago, Hudson River Rick said: @kmmcrafts Thanks for your reply Kevin. I know now that I should have asked how to remove the podt so I could insert the new spring. When I tried to remove the post, there was a good amount of resistance, and I'm not sure if it is a press fit or are ther threads on the rod? @OCtoolguyThank you. Please see my reply to Kevin @dgman Thank you for your resonse. Please see my reply to Kevin I've never taken one of these apart "yet".. but if I had to guess how it comes apart I'd think you'd have to take the top plastic lever off the parts under that lever probably comes off the top to allow the post and the sliding portion to drop out of the bottom. Probably just lower it enough to get the old spring out and the new in.. then slide it back up and hook up the top portion levers pins etc. Looks like some small parts so be cautious not to drop anything, lol I could be all wrong on this.. as I said, I've never took one apart and only guessing based on what Denny said and looking at the pictures. Seems like this would maybe come with some written instruction or diagram etc.. Maybe there is a YouTube video showing the process? OCtoolguy 1 Quote
kmmcrafts Posted October 30, 2024 Report Posted October 30, 2024 (edited) Well I just replied and it didn't show up so I'll try again here. Put the white lever into the tension position and then at the front of the chuck push up on the lower sliding piece and that will give you access to the small pin that holds the lever on. The pin is not really a tight press fit pin as I moved it about half way out with just a flimsy old saw blade.. but a small drill bit would probably work better. Also I believe the metal bushing insert into the lever is not tight fitting either so be sure not to let it fall out while working to replace the spring. To give yourself a extra hand you could probably push up on the sliding piece and tape it in place maybe.. I think once you get the pin out the white lever will just pull up and out of the chuck. Then you drop the sliding part back down to get the spring out and new one in. Then just put the lever back up there and replace that small pin. Should be very simple so long as the parts don't go MIA on you, LOL Here is a couple more photos.. two shows the side view where the pin it.. one shows the pin slightly hidden which is why you have to push up on the sliding part to actually get it up high enough to access that pin. Hope this helps Edited October 30, 2024 by kmmcrafts OCtoolguy 1 Quote
Hudson River Rick Posted October 30, 2024 Author Report Posted October 30, 2024 THANK YOU ALL . Once again this group MAY HAVE solved the problem. I say MAY HAVE, because I don't recall a spring being under the white tension lever, but as we all know S#&@ happens. My guess is that the spring is in NEVER NEVER LAND, hiding in a dust pile and soon to be spinning around in my cyclone dust collector. OCtoolguy 1 Quote
kmmcrafts Posted October 30, 2024 Report Posted October 30, 2024 28 minutes ago, Hudson River Rick said: THANK YOU ALL . Once again this group MAY HAVE solved the problem. I say MAY HAVE, because I don't recall a spring being under the white tension lever, but as we all know S#&@ happens. My guess is that the spring is in NEVER NEVER LAND, hiding in a dust pile and soon to be spinning around in my cyclone dust collector. You have me confused now.. LOL.. The spring is not directly under the white tension lever.. it's in a slot in the chuck head below the lever yes but not directly under it.. You can visibly see it in your photo you posted.. You can't take it out until you pull the pin as the pin goes through the rod that is part of the sliding part.. as you place tension on the blade the sliding part moves upward to pull up on the blade via the white lever. You can sort of see the pin going through the rod in this photo of yours that I marked everything out in color. OCtoolguy 1 Quote
Hudson River Rick Posted October 30, 2024 Author Report Posted October 30, 2024 Kevin, the spring in your illustration, which is drawn over my photo, needs to be there. I believe there is supposed to be s spring that goes over the Rod, but when I pulled the pin out of the tension lever, I did not see a spring fly out. I ordered the parts from Denny, and he is sending me a schematic drawing of the chuck head, so I can see the break down. Thanks again for all your help, I'll let all you guys know how the fix works, when i get back on the air. Rick kmmcrafts and OCtoolguy 1 1 Quote
Scrappile Posted October 30, 2024 Report Posted October 30, 2024 Just my experience, not with your saw, but if things are slipping with the tension lever, the nylon tension lever may need replacing, they can wear out. OCtoolguy 1 Quote
