I was cutting out these ornaments this evening, stack of 5, 1/8" basswood, when I noticed that the stack had shifted ever so slightly. When I tried to feed the blade through the next pilot hole I couldn't because of the shift. My pilot holes in this were #65, .035"; so I used a #71 drill bit, .025" to get the hole realigned, then used three #65 drill bits to keep the whole thing aligned while I used hot glue to hold the silly thing together while I finished cutting.
Yea, it worked. 20241123_232548_113551.thumb.jpg.16672e97b98acfd13475dbb6b69fd742.jpg
20241123_233231_113816.thumb.jpg.abeaab89b94f18edc02bb1165006f84d.jpg20241124_035221_035507.thumb.jpg.43a32786d2398ea88f7d86930b390c72.jpg
Never thought about using a drill bit in the hole like that.. I've had this happen before and run a couple wood screws into scrap areas then remove them and put the screws back in the box when finished. Haven't had this issue since I started using pin nails to hold the stacks..
21 hours ago, Denny Knappen said:
I use double sided tape for stack cutting with no problems.  Just be sure the tape is on the waste area.  I have it on the website.  Here is a link:  Hand Held ATG Tape | Pegas scroll saw
Denny @Denny Knappen, the description is confusing.  What does "Hand Held" mean as applied to tape?  Ditto "Wound in Reverse"?
Is this double-sided tape?
This is atg "tape" (adhesive transfer gun). I've used this extensively at work, 25+ years. It's an adhesive put on a slick backing, when you press the adhesive down you then lift the backing leaving only the thin layer of adhesive. Most versions of the tape are designed to be used in a dispenser called a tape gun. Some versions are designed to be used without a gun.
There are different levels of strength of adhesive; light, medium, high, and "oh my God, it's never going to move".
