I have some, that I purchased years ago.  Turns out I accidentally purchased the "pinned" ones.  I cut the pin off and was able to use it in my DeWalt.  They don't seem to fit in the Excelsior.  I did like them for certain applications but didn't use on a regular basis.  It was usually to make a tenon fit into the hole!
On 12/1/2024 at 8:50 AM, TAIrving said:
I tried them.  Still have them somewhere, haven't used them much or recently.  I bought some and made some, not delighted with either.
Making them is not too hard.  You cut thin strips of sandpaper and glue them together on an old scroll saw blade.
I made some this way,still have some.
12 years ago I bought a set of these.. I did use a couple of them but they were not great.. I had a special project I was working on that needed inside sanding or at least I thought that was the best way to do inlay work at that time.. this was before I knew out to bevel inlay so I was sanding things to make them fit. Anyway they did work for the purpose I bought them for at the time.. however they didn't last too long. and they were a struggle to fit into the saws blade chucks. I had a Dremel 1800 saw at that time.
As others have said, the right blade and know how will result in these being basically useless.. and also as mentioned, I've made a few of my own like the others have stated using sandpaper and old blades.. those homemade ones actually worked way better as they was thin strips as the purchased ones were about 1/4" if memory serves correct.
