Popular Post yamatetsu Posted December 14, 2024 Popular Post Report Posted December 14, 2024 (edited) I found this pic in Scrappile's gallery, liked it and wanted to do it. I couldn't find a pattern, so I used his photo. 27cm x 36.5cm, backer board 6mm, Viking 4mm, 'cheap' DIY store ply, #3 straight blade used This was my first try doing a traditional pattern, it took me about 30 hours to do with a fretsaw. Came out pretty nice (though the photo isn't). Edited December 14, 2024 by yamatetsu ChelCass, Roberta Moreton, barb.j.enders and 9 others 10 2 Quote
GPscroller Posted December 14, 2024 Report Posted December 14, 2024 Well done. Paul (Scrappile) encouraged me to cut this same pattern years ago. He is a great mentor. Jeff yamatetsu 1 Quote
rjweb Posted December 14, 2024 Report Posted December 14, 2024 Excellent cutting, RJ yamatetsu 1 Quote
Scrappile Posted December 14, 2024 Report Posted December 14, 2024 Well done. I went to the site that I purchased the pattern from and it does not appear to be available any more. I did it in 2015 using Flying Dutchman 3/0 New Spiral blades. I do not think I could have done it then or now with straight blades. Quote
JTTHECLOCKMAN Posted December 14, 2024 Report Posted December 14, 2024 Are you talking hand held Fret Saw?? If so more impressive. Hats off to you. Quote
yamatetsu Posted December 14, 2024 Author Report Posted December 14, 2024 2 hours ago, JTTHECLOCKMAN said: Are you talking hand held Fret Saw?? If so more impressive. Hats off to you. Yep, I don't have room (or funds) for machines, I even have to cut the boards using a ryoba. This is the reason why I don't do frames for my pics, because it's just too much of a hassle to do them by hand. The one machine I use is a Dremel knockoff to drill the holes. Dan and Scrappile 2 Quote
yamatetsu Posted December 14, 2024 Author Report Posted December 14, 2024 3 hours ago, Scrappile said: Well done. I went to the site that I purchased the pattern from and it does not appear to be available any more. I did it in 2015 using Flying Dutchman 3/0 New Spiral blades. I do not think I could have done it then or now with straight blades. I've been doing fretsaw work for almost 3 years now, this was done approx. 2 years ago. Back then I knew that it would be hard to do, but not how hard. My fretsaw is 30 cm long, the pic is 36.5 cm high, so there were cuts that needed some creative cutting. I used a #3 blade because that was the only type of blade I knew. Nowadays I would use a #1 blade, but still a straight blade. I have tried using spiral blades, I am able to use them, but that's not for me. I think it's a safe bet that by using a fretsaw the blade moves much slower than that of a scrollsaw. So the blade moves much slower, I use a 4 mm thin board and a relatively crude blade. I can practically hear the wood screaming as the blade chews it's way through it. Being able to saw backwards with a handheld saw is kind of cool, though. Scrappile 1 Quote
JTTHECLOCKMAN Posted December 14, 2024 Report Posted December 14, 2024 1 hour ago, yamatetsu said: I've been doing fretsaw work for almost 3 years now, this was done approx. 2 years ago. Back then I knew that it would be hard to do, but not how hard. My fretsaw is 30 cm long, the pic is 36.5 cm high, so there were cuts that needed some creative cutting. I used a #3 blade because that was the only type of blade I knew. Nowadays I would use a #1 blade, but still a straight blade. I have tried using spiral blades, I am able to use them, but that's not for me. I think it's a safe bet that by using a fretsaw the blade moves much slower than that of a scrollsaw. So the blade moves much slower, I use a 4 mm thin board and a relatively crude blade. I can practically hear the wood screaming as the blade chews it's way through it. Being able to saw backwards with a handheld saw is kind of cool, though. Absolutely more fantastic. I can not even use a coping saw to cut backs of molding. A++++ yamatetsu 1 Quote
