On 12/14/2024 at 7:37 PM, dgman said:
576, which comes to 48 dozen or 4 gross. I actually thought it would be more.
Because inquiry minds want to know, were these from the same manufacture & do you think you used less because they stayed sharper longer?
They were 95% FD UR blades in various sizes. The rest were Pegus blades. The UR blades have a reverse tooth every third tooth. When the blade starts to dull, i reposition it to get fresh teeth. This is easy to do with the Pegas saw. I load the blade as low in the clamp as i can. When dull, i move it up in the holder as far as i can so there are fresh teeth cutting. It’s like doubling the life of the blade! This works on any skip tooth blade and FD UR reverse blades. If you use a regular reverse tooth blade, you will loose the reverse teeth when you reposition it.
