I have a Delta 40-694 and I have broken the blower assy. line that comes off of the side of the saw. I know that there are others on this site who use an aquairiam pump with hose to blow off sawdust. I would appreciate if some folks would weigh in on brand and model of pump that does this job. I don't know what to look for. Thanx in advance. forrest
Did just the plastic flex hose break or did the metal part right at the saw break? If just the plastic line those come apart and you can take out the bad links and reconnect it.. Yes it will be shorter but this saw is much like the Dewalt I had and they come with pretty long flex line when new.. I had this happen a few times on my DeWalt..
They make a special plier tool to help take apart and put back together.. I never needed them as they pull apart not too bad.. putting them back on can be a struggle though.. It helps a lot if you can heat them up in some really hot water for a few minutes to make the plastic a bit more flexible add a drop of soap to help it slide together..
Just get the cheapest one walmart sells.  and some clear tubing.
I put the end of a ball pen into one end of the tube to make it more directional and taped the tube alongside the regular tubing.  Works great and is constantly on when I saw instead of only blowing air like the bellows do.
Total cost should be about $10.
Wow, I appreciate all the responses.  I replaced the broken segment  on line but could not get line attatched to nipple. I tried hot water, blow dryer and cussing without any luck. Finally, I messed with it until it was too short. I'm not sure how I will proceed but i'll let ya'll know how it came out. Merry Christmas to all...... Forrest.....
