Tom Gi Posted December 29, 2024 Report Posted December 29, 2024 I bought a hegner saw used it is the multi max 22v 2024 where the insert is for the blade is the blade supposed to be centered in the line where the table is cut for the blade to go in this one looks like the person before ground out a chunk of the insert for the blade it is off center by a bit is there any adjustment to the table so it could be moved over just a bit and then get a new insert to close up some of the opening OCtoolguy 1 Quote
kmmcrafts Posted December 29, 2024 Report Posted December 29, 2024 Yeah that's not supposed to be like that. You might be able to loosen up the bolts on the table top and center the table top to the blade and then snug it back up... Had to do this on a couple different saws I've had over the years.. but never had one off quite that far. OCtoolguy 1 Quote
Charlie E Posted December 29, 2024 Report Posted December 29, 2024 (edited) My Hegner came from Advanced Machinery with the blade off center like that. They advised me to check the area I have circled to see if it appeared to have shifted in shipping. I could see it had by the paint seal being broken. There is either 1 or 2 bolts underneath that can be loosened to realign this. Edited December 29, 2024 by Charlie E OCtoolguy 1 Quote
Charlie E Posted December 29, 2024 Report Posted December 29, 2024 Also, personally I wouldn’t worry about the insert unless you’re planning on cutting very small pieces. Mine is wallowed out a bit from me putting too much pressure left or and I don’t notice that it affects me at all. Others may disagree. danny and OCtoolguy 2 Quote
Tom Gi Posted December 30, 2024 Author Report Posted December 30, 2024 11 minutes ago, Charlie E said: My Hegner came from Advanced Machinery with the blade off center like that. They advised me to check the area I have circled to see if it appeared to have shifted in shipping. I could see it had by the paint seal being broken. There is either 1 or 2 bolts underneath that can be loosened to realign this. OCtoolguy 1 Quote
Tom Gi Posted December 30, 2024 Author Report Posted December 30, 2024 Thanks I will look at that spot and adjust if possible OCtoolguy 1 Quote
Tom Gi Posted December 30, 2024 Author Report Posted December 30, 2024 15 minutes ago, Charlie E said: My Hegner came from Advanced Machinery with the blade off center like that. They advised me to check the area I have circled to see if it appeared to have shifted in shipping. I could see it had by the paint seal being broken. There is either 1 or 2 bolts underneath that can be loosened to realign this. 15 minutes ago, Charlie E said: My Hegner came from Advanced Machinery with the blade off center like that. They advised me to check the area I have circled to see if it appeared to have shifted in shipping. I could see it had by the paint seal being broken. There is either 1 or 2 bolts underneath that can be loosened to realign this. Thanks I will look there when I get back out to the shop OCtoolguy 1 Quote
JTTHECLOCKMAN Posted December 30, 2024 Report Posted December 30, 2024 Check to see if the table is 90 degrees to the blade before you move the table. If it is then do as other suggested and move the table top. OCtoolguy 1 Quote
Tom Gi Posted December 30, 2024 Author Report Posted December 30, 2024 3 hours ago, JTTHECLOCKMAN said: Check to see if the table is 90 degrees to the blade before you move the table. If it is then do as other suggested and move the table top. I don’t see anywhere to move the table is there any adjustment to it. is there a manual on line OCtoolguy 1 Quote
Wichman Posted December 30, 2024 Report Posted December 30, 2024 55 minutes ago, Tom Gi said: I don’t see anywhere to move the table is there any adjustment to it. is there a manual on line https://www.advmachinery.com/pages/hegner-scroll-saw-instruction-manual?_pos=1&_sid=a6b64a089&_ss=r JTTHECLOCKMAN and OCtoolguy 1 1 Quote
Tom Gi Posted December 31, 2024 Author Report Posted December 31, 2024 On 12/29/2024 at 5:50 PM, Charlie E said: My Hegner came from Advanced Machinery with the blade off center like that. They advised me to check the area I have circled to see if it appeared to have shifted in shipping. I could see it had by the paint seal being broken. There is either 1 or 2 bolts underneath that can be loosened to realign this. I took it apart today and got it adjusted the way it should be . one of the screws was stripped out that holds the motor so three holding should be on thanks for the help Charlie E, Scrappile and OCtoolguy 3 Quote
OCtoolguy Posted January 1 Report Posted January 1 23 hours ago, Tom Gi said: I took it apart today and got it adjusted the way it should be . one of the screws was stripped out that holds the motor so three holding should be on thanks for the help The Hegner saws are very finicky about the screws/bolts holding everything together. If one of your motor bolts is stripped out, I'd either drill and tap to the next size or Heli-coil the hole back to original. I know for fact that if you loosen the 3 bolts that hold the saw to the stand, there is an order in which you should tighten them to avoid vibration. I experimented with mine and it is true. If I recall, you have to tighten the two front bolts nearest the operator and then snug the 3rd at the rear of the saw. As for the insert, if you feel a need to have a zero clearance insert, just take a playing card, slit it half way through and then tape it to the table top. If it gets "wollered" out, just put a new card in it's place. Quote
