Sam777 Posted December 30, 2024 Report Posted December 30, 2024 Hello all, Happy new year to the forum members Please help I made a couple of 3/4 walnut text pieces and would like to them in liquid finish to get into all the cuts and corners and dry quickly. What can I use? Thank you in advance Quote
BadBob Posted December 31, 2024 Report Posted December 31, 2024 Shellac works pretty well if you thin it. Thin the caned shellac with an equal part of denatured alcohol. Dip it and let it soak for a short time, then wipe off the excess. I sometimes have to blow it out of sharp corners. barb.j.enders and Wichman 2 Quote
Dan Posted January 3 Report Posted January 3 I've thinned polyurethane be with mineral spirits (50/50) and it dries fast, but not as fast as shellac. What ever you use, be sure to wipe down all the drips before the start setting up. barb.j.enders and danny 2 Quote
Roberta Moreton Posted January 4 Report Posted January 4 I use Natural Danish Oil. Dip, let drip a little while, wipe, and done. danny 1 Quote
GreggA Posted January 26 Report Posted January 26 On 1/4/2025 at 4:22 PM, Roberta Moreton said: I use Natural Danish Oil. Dip, let drip a little while, wipe, and done. Do you put anything else on top of it, for a gloss finish or just the danish oil? Quote
JTTHECLOCKMAN Posted January 26 Report Posted January 26 I too am a dipper in Danish oil. I love Watco Danish oil. I sand all my projects to 220 grit. Then dip and drain and wipe. Let dry for a few days. The small amount of poly in the Danish oil will give a nice warm glow and feel to the piece. Now on occasions like with shelves I will put a light coat of Watco liquid wax on them. Have to be careful not to get into fret work because you will not be able to wipe it out and it could clump. I just put small amount on a soft cotton cloth if I do this. But most times not needed. barb.j.enders 1 Quote
Dan Posted January 26 Report Posted January 26 When I dip ornaments I dip and hang them for about 15 minutes, then wipe off the access. I use compressed air set to about 15 psi to blow drips from the crevasses and give them one more wipe down and hang them to dry. This works for most oils. Quote
BadBob Posted January 27 Report Posted January 27 14 hours ago, Dan said: I use compressed air set to about 15 psi to blow drips from the crevasses and give them one more wipe down and hang them to dry. I have a battery-powered handheld blower that I use for this. danny and Mike Crosa 2 Quote
Roberta Moreton Posted January 28 Report Posted January 28 On 1/26/2025 at 12:19 PM, GreggA said: Do you put anything else on top of it, for a gloss finish or just the danish oil? No, nothing else. I have dipped a second time to see if it made a difference. The difference was small. A little more shine and color. Quote
rash_powder Posted January 28 Report Posted January 28 I like to use boiled linseed oil thinned about 50% with mineral spirits. I feel it gives the ornaments I make (mostly from Poplar) a vintage look. They darken a little with time and light exposure, but I like that antique appearance. barb.j.enders 1 Quote
tomsteve Posted February 1 Report Posted February 1 finish to get into all cuts and corners and dry quickly. when in that situation I use lacquer in a rattle can. I spray light misting coats from angles working at getting the nooks and crannies. light misting coats- I'm not trying to get full coverage in one pass but want to get full coverage in 2-3. then a final coat spraying on top and done. works pretty good for me. Quote
