My question how many people use their blade guards on their scroll saw? I'm asking because to me at times it is a nuisance at times when having to insert your blades thru your projects. Btw I'm using the 22 in Bauer.
Edited by GreggA
I find the relative safety of a scrollsaw to be one of the biggest perks of the tool.  Aside from the blade breaking and possibly spearing you, I just cant imagine how hard you would have to shove your finger into those tiny teeth that they would actually cut you badly.  I've touched the blade while running at full speed just to see what would happen, and I have to say I get worse wounds from our cats when they decide to jump off you while being carried.
I dislike modifying machine without a lot of studying and trepidation. That said, I have removed every blade guard on every scroll saw I've owned, they just get in the way and don't afford much protection. This is also the only tool that I've removed a blade guard from.
Only place I used them is when our club was at a Boys club and the director thought it would be a good idea.  He was not a woodworker.
A real pain so when we moved all the guards came off and we never have had an issue,  We have 40 - 50 Cubs each year come and scroll for the first time o problems.
have never used a blade guard and have on ocaission run a finger into a moving blade with no problems, except once I received a minor skin tear when using a larger blade #12.
My grandaughter did receive a bruise from the blade tightener knob. A guard would not have prevented that as the tightener knob is outside of any protection the guard would have offered.
Once, when I wasn't payibg attention, I was pushing at the end of a cut and pushed my thumb into the blade. I got a bit of a cut but nothing to write home about. It drew blood but not much.
If you are more comfortable having it mounted on the saw, leave it there. As you can see from all of the responses, nobody really uses a blade guard. Yes, they get in the way with blade changes and inserting the blade into your project. Personally, I have never used the blade guard and only knicked myself once with a number 5 blade. Bleed for 30 seconds and stopped. You really do have to try to hurt yourself on a Scrollsaw.
