DW 788... big problem!!!
bubbaloo158
Howdy all...
I was just doing some cutting on my 788. While threading a hole my foot accidently touched the pedal while the arm was up. It made a funny noise. I finished getting ready for the cut. I stepped on the pedal. Nothing. Keep in mind that I only TOUCHED the pedal - just a tap - nothing more.
The first thing I checked was the pedal... I plugged in the light and it was working fine. I then noticed what looked like a reset button on or near the motor. I depressed this, held it for about 60 seconds, and still nothing. I do know that it isn't one of my house breakers because everything else I plugged into the same plug works. I am at a loss as to what happened. Surely I didn't burn the motor, did I??? I'm in panic mode here.
Hoping some of the great wisdom that I get from here all the time will come through and get me up and running again.
Bobby
After I put up my post about my problem I went back down to the shop. Just for fun I had a look up in one of the cupboards to see if I could find the manual. I wasn't holding my breath over it because I am notorious for misplacing manuals. Who needs them right? Well lo and be hold, there it was!!! I couldn't believe my good fortune. I came to the page with some fuse info and knew that my problem was solved. I went up to the electronics store and got the new fuses, rushed back home to put them in. Success!!! Learning something new every day.
Bobby
I blew one of those fuses also! I have no idea how I did it. That was about 2-1/2 years ago. I have used it a lot harder since and never blown another one. I do keep a few in the same box; that I keep my blades in.
Happy New Year and A VERY MERRY CHRISTMAS to all of the sawdusters!
Can you tell us where the fuse is located and the size (amp rating) of it just in case some of us don't have an owners manual.
OK I answered my own question here is the link and the fuse should be avaliable at any radio shack type store
its item 112 on the diagram
http://www.ereplacem..._2631_2632.html
Edited by qlty
