hi all,
just discovered this site in my searching, great idea!
From Australia here, where scrolling is a hobby very much in its infancy; materials and supplies difficult to find locally, thank god for the internet! I discovered the scrollsaw hobby quite by accident when a friend told me about a book that I went hunting for, and discovered another book about segmentation. Managed to find a cheapy scrollsaw from Aldi of all places. Was good enough to get me going, but soon realised the limitations of pinned blades and other drawbacks. Upgraded to a DeWalt 788 (had to order one from New Zealand of all places; at the time, the only other option available in this country was a Hegner... a bit beyond my budget--at least according to my wife!--) and been happy ever since.
Got a handle on segmentation and fretwork OK, just starting out on the intarsia now... a bit daunting getting those 'perfect' cuts. Not quite there yet, but I do tend to be over-ambitious and start on complex things! Now trying to work out how to fix/hide not quite accurate cuts... some pieces seem close enough to not need a re-cut, but do need a better fit... help and advice is most welcome!
Regards to all from a new addict,
Rippy
Hi Rippy and welcome to the village. Intarsia can be very time consuming and frustrating with getting everything to fit just right. Don't give up. The biggest thing that I have found is to make sure all the edges are square(blade didn't cut on an angle) that helps alot.
Hi Clayton, thanks for the welcome. My problem is cutting on the lines! Squaring is OK, I generally can manage that, but I do waver off the lines a bit. Experimenting with different blades at the moment... I'm very used to size 2/0 blades for what i've been doing so far, and has been a big mind shift to switch to larger blades; I tend to use #3 blades at the moment, might need to go to #5 for greater accuracy.
cheers
Rippy
Rippy, when I'm cutting out my intarsia i use a # 5 and a # 7 especially if I'm cutting thicker wood. The Jesus I just finished(makes 9 of them) I use 1"thick walnut. The # 7 cuts through it pretty well. Not sure if this is the "correct blade" but it works well for me.
Welcome to the Village, Rippy! We're glad to have you on board.
... but I do tend to be over-ambitious and start on complex things!...
I completely understand this statement! LOL...I've never done intarsia before, so I thought I'd start a project that has 265 pieces in it! :oops: I'm having a great time with it, though. I'm not an accurate cutter either, but I'm OK with it. I'm really enjoying using woods I don't normally have access to. I have been using a #5 for most of my cutting. I seem to have better control with it on the thicker wood. But the wood I'm using probably doesn't go much beyond 5/8". Anyway, we'd love to see some of your work. You can set up a User Gallery to show off a little (you can find a tutorial here). Jump on in and have some fun!
Wow, what a welcome! Thanks everybody.... and yes, I think my blade choice is too small for the wood and accuracy I need, erm, want! Will take some pics and get a gallery happening.
cheers all.
  • 3 years later...
