Toninho Posted March 16, 2013 Report Share Posted March 16, 2013 (edited) Hello friends!I would like to know your opinion!I usually cut puzzles and other projects in maritime cluster. I paste the pattern before use sandpaper to remove the pattern well after cutting. But still always starts pieces of wood. What should I do to avoid damaging the work!?Excuse my traduçao! Edited March 16, 2013 by Toninho Quote Link to comment Share on other sites More sharing options...
Tdub4ever Posted March 17, 2013 Report Share Posted March 17, 2013 Don't know if I really understand the question, but if you're saying you sand the pattern off when finished cutting and damaging the wood. You can use mineral spirits or paint thinner to remove the pattern. What I do is brush on some mineral spirits and let sit for a couple minutes and the pattern comes right off. Then just wipe down the project with a lint free cloth dampened with mineral spirits to remove the residue. Hope this answers your question. Travis and Toninho 2 Quote Link to comment Share on other sites More sharing options...
Scrappy Scroller Posted March 18, 2013 Report Share Posted March 18, 2013 Hi Toniho You could try this for your 'other' projects (not puzzles) - Cover the marine ply wood with white masking tape first. Then spray adhesive on your pattern and stick this to your wood. Then use sellotape / clear tape over the top. I think that using reverse blades also helps eliminate splinters When you have cut your pattern the white masking tape should peel off easily leaving no residue. I am not sure, but I think people who make puzzles use a spray varnish and cut with special blades, but I think they leave the pattern on the wood. Gary Quote Link to comment Share on other sites More sharing options...
spirithorse Posted March 19, 2013 Report Share Posted March 19, 2013 Oi, Toniho, Gary deram-lhe o mesmo conselho que eu iria. Use a fita do Pintor que mascara na madeira e cola de borrifo de uso anexar o padrão à fita do pintor. Depois que você corta o projeto, a fita do pintor retirará muito facilmente da madeira com resÃduo muito pequeno. O deus Abençoa! Spirithorse Quote Link to comment Share on other sites More sharing options...
Toninho Posted March 22, 2013 Author Report Share Posted March 22, 2013 My question was this same @Tdub4ever!!! thank you for your great help. Good weekend! Quote Link to comment Share on other sites More sharing options...
Toninho Posted March 22, 2013 Author Report Share Posted March 22, 2013 @Gary Thank you Gary! I discovered what I was doing wrong. First step: put yellow tape painter's tape after passing over the transparent adhesive tape and then spray painter with spray glue on top of the transparent tape and finally put the pattern!My mistake!Now I will follow your advice!Greetings from Portugal! Quote Link to comment Share on other sites More sharing options...
Toninho Posted March 22, 2013 Author Report Share Posted March 22, 2013 Thanks for your help @ spirithorse!!! Gostei de ler suas palavras escritas em portugues! Quote Link to comment Share on other sites More sharing options...
amazingkevin Posted April 2, 2013 Report Share Posted April 2, 2013 I've never tryed these ideas but they all should work great .thanks for the info group! Quote Link to comment Share on other sites More sharing options...
