gator Posted April 15, 2013 Report Share Posted April 15, 2013 (edited) okay looking for guidance from the group. years ago when the ca glues came out wasn't a big fan cause i noticed the joint would break after awhile. used the old Elmer wood glue. fast forward to last year. we started using the tigh bond 1 since went to green #3 tigh bond. while doing the chess board i started using the insta-cure with a accelerator. love it with trim on a project you can just keep moving quick. question is how long will it hold? what are some of your others experiences and what do you use? Edited April 16, 2013 by gator Quote Link to comment Share on other sites More sharing options...
amazingkevin Posted April 15, 2013 Report Share Posted April 15, 2013 Hi Gator ,i'm not happy with all the glues i've used .Probably cause of my budget.But i will try the green tite bond now as your useing it and that should be good for my applications too.Thats all i can add . Quote Link to comment Share on other sites More sharing options...
gator Posted April 15, 2013 Author Report Share Posted April 15, 2013 its a water proof glue we just like it but dont mean there ant better. all projects out side or inside. but am using the ca on scroll saw just not sure yet looking for some more input from long timers here Quote Link to comment Share on other sites More sharing options...
Travis Posted April 15, 2013 Report Share Posted April 15, 2013 I've only used CA glue on woodturnings or fixing plastic Chinese toys. I never used it for joining boards. I have a feeling that you might be correct, the glue is brittle. I've seen some folks use a combination of CA glue and wood glue. They glue up the joint like normal, but use CA glue to tack it in place while the woodglue cures. Spread wood glue, then a dab of CA glue on one side, accelerator spray on the other piece, then press together? You'd have to do it right the first time, because once that accelerator and CA glue meet, it's a done deal. Might be worth experimenting with. Quote Link to comment Share on other sites More sharing options...
Clayton717 Posted April 16, 2013 Report Share Posted April 16, 2013 I use CA glue alot. if I want or need somthing dried fast I use it. I really haven't had problems with the CA holding. i use it for glueing in my tubes and finish on all my pens. the Kenworth I just finished is almost entirely glued with CA glue, that way I didn't have to wait for all the pieces to dry I could just keep moving. For regular wood glue I now use tight bond 3 Travis 1 Quote Link to comment Share on other sites More sharing options...
WolfmoonCT Posted April 16, 2013 Report Share Posted April 16, 2013 I don't join boards with CA.. watch out for the T3 waterproof glue on light woods, they say you can see a glue line because the wood is a gray color.. I still use T1.. Quote Link to comment Share on other sites More sharing options...
