Gary Unruh Posted April 21, 2013 Report Posted April 21, 2013 How can I transfer a b&W pattern (jpg) to the wood? Quote
koehler788 Posted April 21, 2013 Report Posted April 21, 2013 I usually make a copy of my pattern and apply it directly to the wood with repositionable spray adhesive. (spray the pattern - let it tack up - and apply ). If left on too long - just use mineral spirits to loosen. Quote
koehler788 Posted April 21, 2013 Report Posted April 21, 2013 Here are a couple more pics Travis 1 Quote
Uncle Ricky Posted April 21, 2013 Report Posted April 21, 2013 I use carbon paper and put my black and white pattern over it and trace it out, I know it's an old way of doing it. lol Quote
Gary Unruh Posted April 21, 2013 Author Report Posted April 21, 2013 What is repositionable spray adhesive and where do you get it? Brand name? Quote
Gary Unruh Posted April 21, 2013 Author Report Posted April 21, 2013 Can you just use computer printer paper to make a patern? Quote
Scrappy Scroller Posted April 21, 2013 Report Posted April 21, 2013 Hi Gary You print the pattern and then use the adhesive to glue it to the wood, I think 3M do it along with a few other brand names. Gary Quote
don in brooklin on Posted April 21, 2013 Report Posted April 21, 2013 I cover my wood completely with painters tape. Blue or Green. Spray the back of the pattern with glue or with a glue stick. Apply to the taped side and the tape is easy to remove. If hard wood, I cover the back with clear shipping tape. Don Quote
koehler788 Posted April 22, 2013 Report Posted April 22, 2013 Don, That is a good idea, Shipping Tape also acts as lubricant for the blade ( so I am Told ) Quote
wombatie Posted April 22, 2013 Report Posted April 22, 2013 I also use blue painters tape but if I know that it will take me a while to cut I spray both the pattern and the side the painters tape is on and it will stay there until I am finished and pull the painters tape off. Marg Quote
trailfndr Posted April 23, 2013 Report Posted April 23, 2013 I cover the wood surface with white contact paper, and then apply the paper pattern using the spray adhesive. This elliminates any cleanup of the wood, as the contact paper peels right off easily. I also cover with Clear packing tape, and it does make a difference in the amount of cutting I get from a blade. Printer paper works very well. Its all I have used, I spray the adhesive to the back of the pattern, position it on the contact paper, and then tape it before cutting. MUCH easier to follow the printed lines vs the traced ones, and accuracy is greatly improved. On larger Intarsia patterns, I make multiple copies (usually 4 or 5 will work) and then cut out each individual piece, and apply them to the wood. makes a big difference in fitting parts together. Quote
