edward Posted July 28, 2013 Report Posted July 28, 2013 I stacked two 1/4" oak ply together to cut out a train portrait, got 1/2 way done in the cutting and felt something different while cutting, just sounded hollow, check it out and a 1/4" gap in it.Kinda think it is ruined, so I will save some sawdust and mix some glue with it and see if it works. The wood seemed solid when I checked it out before I started. Has anyone else ran into this problem. edward lawson56 1 Quote
kardar2 Posted July 28, 2013 Report Posted July 28, 2013 Yep you are using cheap plywood from the big box store if you count the layers in different plywood you will see the difference. Don't buy birch plywood from the big box store either. amazingkevin 1 Quote
MrsN Posted July 29, 2013 Report Posted July 29, 2013 It might be salvageable. As hard as it is try finishing the piece. Quote
sullyscroller Posted July 29, 2013 Report Posted July 29, 2013 Edward , been there done that. It's called a void . The 1/4" oak and birch ply at lowes and home depot is not real ply any more ,it's 2 ultra thin veneers with junk inbetween. I now use a ply called Sureply from lowes and have great finished fretwork with it. It's basicaly 1/4" underlayment . has x's for nailing on one side but the other side is really nice. It cuts really nice and tales a finish well. A 4x8 sheet runs about $20. Hope this helps. sully Quote
lawson56 Posted July 29, 2013 Report Posted July 29, 2013 (edited) I have run into the same problem.I have managed to finish the project.then fill the gap with putty.Luckly it's thin wood not much to fill.Lesson learned. Edited July 29, 2013 by lawson56 Quote
edward Posted July 29, 2013 Author Report Posted July 29, 2013 Tried filling the gap with cuttings of sawdust and glue, didn't really care for the outcome, Thanks for the comments. edward Quote
amazingkevin Posted October 18, 2013 Report Posted October 18, 2013 THAT WAS A LESSON LEARNED THE HARD WAY.I did a similar mistake by using way to thin a material and letters would vanish.i finish the piece because of what it was "THE LORDS PRAYER" Quote
