Clozy Posted July 30, 2013 Report Share Posted July 30, 2013 Good morning all, hope your day/night is going well, I need a bit of advice on finishing off projects, I have been finish coating my projects by hand which is a real pain in the neck, and was wondering, as to what route I should go in getting a spray system, I don't have loads of space in my work shop, I was thinking of getting either a airless spray gun or an air brush, can anyone pass on a bit of their expertise as to my request. Thanking you Les. Quote Link to comment Share on other sites More sharing options...
lawson56 Posted July 30, 2013 Report Share Posted July 30, 2013 Well I don't know if this will help,but after I sand my cuttings down some.I spray a coat of clearcoat on them,After staing them of course.Unless the customer wants the brush on clearcoat.Hope this helps in some way. Quote Link to comment Share on other sites More sharing options...
WolfmoonCT Posted July 30, 2013 Report Share Posted July 30, 2013 I spray all mine with Satin Poly Quote Link to comment Share on other sites More sharing options...
MrsN Posted July 30, 2013 Report Share Posted July 30, 2013 I use rattle can type spray finishes. I don't have room to dedicate to finishing so I use the garage or outside. I like a spray lacquer or rustoleum 2x coverage clear spray. My personal preference is glossy. Phantom Scroller 1 Quote Link to comment Share on other sites More sharing options...
Phantom Scroller Posted July 30, 2013 Report Share Posted July 30, 2013 Spray lacquer for me high gloss. from the old rattle tin as Katie said. Roly Quote Link to comment Share on other sites More sharing options...
Jim Finn Posted July 30, 2013 Report Share Posted July 30, 2013 I use a rattle can from Walmart for under $4. It is a clear acrylic finish, dries quickly. Quote Link to comment Share on other sites More sharing options...
Clayton717 Posted July 30, 2013 Report Share Posted July 30, 2013 for my intarsia I use a brush on mixture of poly, tung oil, and mineral spirits. For other projects I often use spray can of clear. I like the rustoleum 2X from home depot or walmart. It covers well and 1 coat of it is really like 2 coats of others. I do have a cheap air sprayer from harbor freight I use as well for certain things, where I will spray my mixture. Quote Link to comment Share on other sites More sharing options...
sullyscroller Posted July 31, 2013 Report Share Posted July 31, 2013 (edited) I use water based clear poly and spray with a spray gun. No fumes, dries fast,easy cleanup, available at lowes and home depot. Only downside is that it will raise the grain slightly.I use it on everything i do. sully Edited July 31, 2013 by sullyscroller Quote Link to comment Share on other sites More sharing options...
grampa Posted July 31, 2013 Report Share Posted July 31, 2013 I dunk mine in a large bucket of paint, I love the large runs you get when it's dry lol. I use stain and Danish oil with a airbrush....paul sullyscroller 1 Quote Link to comment Share on other sites More sharing options...
Phantom Scroller Posted July 31, 2013 Report Share Posted July 31, 2013 I use water based clear poly and spray with a spray gun. No fumes, dries fast,easy cleanup, available at lowes and home depot. Only downside is that it will raise the grain slightly.I use it on everything i do. sully Sully what do you use to clean the equipment up afterwards if your using a gun?? Roly Quote Link to comment Share on other sites More sharing options...
sullyscroller Posted July 31, 2013 Report Share Posted July 31, 2013 (edited) Roly thats the best part about the water based, I rinse the can out with water then fill it half full again with water and spray at 90 psi for a few seconds. do this say 3 times and yer done. It's non toxic so ya can just throw the water out or down the drain sully Edited July 31, 2013 by sullyscroller Quote Link to comment Share on other sites More sharing options...
amazingkevin Posted August 1, 2013 Report Share Posted August 1, 2013 I submerse the project in what ever medium i' m using at the time and wipe off the excess. Quote Link to comment Share on other sites More sharing options...
