amazingkevin Posted September 13, 2013 Report Posted September 13, 2013 (edited) this is what I glued the wood floor togrther with after I cut off bad ends ,chips etc,not sure if this is what clayton puts on his pens?Drys in 10 seconds!or right now when you spray the activater on,You can apply one to one piece of wood and the activator to the other piece of wood connect them and walla it's glued tight no break fix. Edited September 14, 2013 by amazingkevin Quote
DWSUDEKUM Posted September 14, 2013 Report Posted September 14, 2013 I use it some times but I like a bit more time to work with my pieces than that I use basically Titetbond III DW Quote
Clayton717 Posted September 14, 2013 Report Posted September 14, 2013 yes Kevin CA glue is what I use on my pens, not that brand but ca glue Quote
amazingkevin Posted September 14, 2013 Author Report Posted September 14, 2013 thanks good to know Quote
Phantom Scroller Posted September 14, 2013 Report Posted September 14, 2013 Wow that's good stuff Kevin might try some out. Roly Quote
amazingkevin Posted September 14, 2013 Author Report Posted September 14, 2013 I'll tell you this though,i just about stuck my whole hand together as I don't see so good any more and had no idea that much came out of the bottle already. Phantom Scroller 1 Quote
Phantom Scroller Posted September 14, 2013 Report Posted September 14, 2013 I'll tell you this though,i just about stuck my whole hand together as I don't see so good any more and had no idea that much came out of the bottle already. You should check out youtube to see how to use it. haaa haaa.lol Roly amazingkevin 1 Quote
amazingkevin Posted September 14, 2013 Author Report Posted September 14, 2013 Is that how they do it in hartpury? Quote
Phantom Scroller Posted September 14, 2013 Report Posted September 14, 2013 Yep I check out everything out on YouTube first, there's always a person who's had a go before you. amazing what on there. Roly amazingkevin 1 Quote
Clozy Posted September 19, 2013 Report Posted September 19, 2013 I use CA glue when I do stack cutting on ply, a tiny drop on each corner between layers clamp for a few seconds and away I go, the glued corners are going to be waste anyway, saves time taping all the layers together. Les. Phantom Scroller, Travis, Fab4 and 2 others 5 Quote
Travis Posted September 20, 2013 Report Posted September 20, 2013 I use CA glue when I do stack cutting on ply, a tiny drop on each corner between layers clamp for a few seconds and away I go, the glued corners are going to be waste anyway, saves time taping all the layers together. Les. Great idea! Quote
WolfmoonCT Posted September 23, 2013 Report Posted September 23, 2013 I use CA glue when I do stack cutting on ply, a tiny drop on each corner between layers clamp for a few seconds and away I go, the glued corners are going to be waste anyway, saves time taping all the layers together. Les. I like that idea too.. gonna have to try it on my next stack cut. Quote
gator Posted September 29, 2013 Report Posted September 29, 2013 i used ca also on some projects but some trucks i made the bond on the axles bond broke after awhile. went back to tidebond 3 , do like the stack cutting glue up idea thanks Quote
