It will hit the bottom either way. I don't know if there was ever any repair work done I bought it second hand.  It is a type one though so it was supposed to be the better saw.
Thanks everybody.
just a thought did you measure the angle with a battery angle thing of a jig.  I have done that and found the angle on the machine is not necessarily  the actual angle. I did do 45 degree on the dewalt do not remember the outcome but did think sandit hit like yours. as with other I don't usually to 45's but if I need that I usually do that on the sander if small piece or saw if larger wood
mine has a blade tighten modification on the top blade tightening screw .a simple one ,just a bottle cap glued over it to permit easyer turning and it hits before I get to 45 a little but yours is on the bottom of the saw.????cant help you BUT a picture is worth a thousand words and someone will see the problem immediately.show the saw I several positions and angles .Will solve the problem for you. :)
ok mine is new so it does the same thing yours does at 40 degrees so that's the way they designed it.good to know.thanks for pointing it out i'd have never thought about it.good thing you sent the picture,that way i knew right where to look.
