That is one great looking cutting and well done.  My first questions was going to be who is Bob Shellenbarger but later you mentioned Wooden Teddy Bear so I know where to look for it.
Thanks you sharing this work with us.
jim
penqin
I presume and hope that some of you guys are going to try to cut this piece. A word from experience, cut the interior free standing pieces first and then protect that area with clear packing tape. Also, I recommend stack cutting at least 2 thin pieces of ply because the piece is so delicut you might not successfully sand the bottom piece without breaking things off. (I stack cut 4 pieces and finished sanding 2 without breakage.) I recommend hand sanding all of the interior parts. Good luck!
