What are some of the best blades? I have some Pagas blades from Woodcraft and they seem to break easy. I also bought some Oleson blades and they seemed to be better. I bought some Flying Dutchman blades from Mike and am hoping they are good blades, havent got them yet.
Well I'm probably exposing myself as a rank neophyte for jumping into this conversation. I agree that Flying Dutchman blades are high quality, consistent, and hold an edge well. That said I find I have a hard time controlling them when sawing thin stock. I don't know if the teeth are that much more aggressive, or (more likely) I just haven't learned how to control them yet. I have good luck with Olson blades, although I don't think the quality of cut is as good, at least I seem to ruin fewer boards. I'm still practicing with the Dutchman blades hoping I can figure it out.
Flying Dutchman are terrific. Mike delivers awesome customer service and if you tell him the type of woods and thicknesses you commonly use, he can help you select the best blades for you. I love the spirals, puzzle blades, and Ultra Reverse. Let us know what you think once you get them.
Control is a combination of quite a few factors. Saw vibration, skill, type of wood, type of blade, etc. If you are cutting 1/4" or thinner stock, you may want to try a smaller sized blade (#2 or #3 instead of #5 or #7). Also, selecting a blade with more teeth per inch (TPI) will give you a bit more control as well since they can't clear the sawdust as fast and the teeth are smaller. You could also try stack cutting a few pieces of the thin stock. This will provide more resistance and cause the blade to cut slower.
The short version of the answer is to keep trying different blades and practicing until you come up with what combination works for you. That's the best part about this hobby. There is no right or wrong way, it's all about what does the trick for you.
BArry
Here is my take on this matter..If I am cutting thin stock, I usually do one of 2 things..
1. Stack cut,,(this means I am now, not just cutting thin stock and this makes the blade work a little slower and while supporting the original, weaker board
2. I also choose a smaller blade like a puzzle blade, but for thin cuts I prefer the Olson double reversable tooth blade with the most teeth per inch
The reason i prefer the olson blade here is because flying Dutchman does not offer a double tooth blade to my knowledge, this blade cuts slower, while being very accurate and is small enough to make tight cuts and leaves very little frizzies at the same time. I usually use a #3 so it is not a weak blade. and tracks well
Dick
heppnerguy
I use Olson only..  FD are good, but I just love Olson.  i do nearly everying I cut using a #2/0 R blade I get from Sloans.  I usually buy a gross at a time. 99% of my stock is 3/8" thick or less.  I'd say 95% of everything I cut is 3/8" thick.  Oak, cherry, ash, maple, gonna use some quarter sawn sycamore I got eventually.  I find the Olson cut beautiful and leave no burrs and a nice clean line.
There you go,, Try different blades for yourself and find the one you enjoy working with.. that will be the 'best blade', as least for you. Blades are not expensive and try to keep notes on the different ones you try and then you will come to your own conclusion.
Good luck with it. I am still experimenting with my blades.
Dick
heppnerguy
I too like the Olsen blades better than the FD's. I find the FD's take longer to make a turn. I have to stop short of the turn and wait for the blade to finally turn the corner. If I don't I overshoot the line on the corner. This happens at all speeds. With the Olsens I can go all the way to the corner and spin on a dime and it responds as quickly as I do. My 2 cents worth. :)
I found the same thing with some of the FD blades. I don't have that problem with the Ultra Reverse but with many of the others I had the exact same problem.
Barry
  • 2 weeks later...
Sparkey, I agree with most of the others who've replied, and IMO there's none better then Flying Dutchman blades. I've found that sometimes the Ultra blades are to aggressive though, so, I will switch to the Flying Dutchman Scroll Reverse blades. They give you pretty much the same cut finish, and they were the "go to" blade before the FD-UR came on the market. It's usually good to have both types of blades on hand, so that you can switch when you want. Mike is a fantastic person, he'll do whatever he can to help you out. Any time you have a question, he's the guy to call. Let him know what you plan to be cutting, and he'll make sure that you're set up with the right blade. Plus, like the others have suggested, try out different types or sizes, Mike has a sample pack that would be good for you to try out.
Len
The reverse blades are great because the teeth pointing up on the bottom of the blade help remove any fuzzies left over from the downstroke. If 1/4 inch is what you normally cut you should have no problem with the blades. Just remember, alot of how well a blade works for you will be determined by your cutting style rather than which blade.
Barry
Thanks Barry I will stop at woodcraft when I am out today and pick up a pack. As far as the fuzzies a friend at work told me a little trick. I have a little butane soldering torch and if you run the flame along the back edges the fuzzies go away. I tried that on the two I ave done so far and it worked really good.
