amazingkevin Posted December 20, 2013 Report Posted December 20, 2013 i need to glue many thin pieces of wood together to make a blank to use for a project.Glueing one at a time both sides is tedious .i want to press all the wood to a soldid non moving dead end and have the clamp open easyly to add one piece at a time in the mix of things.something simalar to a carpet strecher is needed the blanks will be no more than 13 '' as that's all i can but thru the planer i never used .any suggestions is helpfull.please and thank you! Quote
LarryEA Posted December 20, 2013 Report Posted December 20, 2013 Whew, Over my head. Sorry Kevin Larry Quote
scroller111 Posted December 20, 2013 Report Posted December 20, 2013 Kevin, Depending on how wide you want to go, you can use a couple of pipe clamps. That way they are long enough to put in as many pieces as you want. I hope this is helpful Quote
oldhudson Posted December 20, 2013 Report Posted December 20, 2013 i need to glue many thin pieces of wood together to make a blank to use for a project.Glueing one at a time both sides is tedious .i want to press all the wood to a soldid non moving dead end and have the clamp open easyly to add one piece at a time in the mix of things.something simalar to a carpet strecher is needed the blanks will be no more than 13 '' as that's all i can but thru the planer i never used .any suggestions is helpfull.please and thank you! If I've understood you correctly, you want to make a gluing form. Cut a sheet of 3/4" mdf to create the base of your form. Then cut and screw additional pieces, cut at a right angle, to create the "dead end". Screwing the "dead end" to the base. Then cut and screw together the other portion of the form. Cover all the pices with packing tape so when everything is clamped the blank doesn't adhear to the form. Here's a Youtube video of what I'm talking about. The video is for 'bent' lamination but I think you'll see what I'm trying to explain. Hope this helps. Wilson's Woodworking 1 Quote
jscottj Posted December 21, 2013 Report Posted December 21, 2013 didn't have time to view the video, but i thought of holes in the base for pins made of dowel and wedges that can be pulled and moved easily amazingkevin 1 Quote
Wilson's Woodworking Posted January 2, 2014 Report Posted January 2, 2014 Thank you Oldhudson for sharing that video. It was very informative and gives me some great ideas. Quote
amazingkevin Posted January 4, 2014 Author Report Posted January 4, 2014 ol hudson saves me alot lately Quote
