DWSUDEKUM Posted January 11, 2014 Report Posted January 11, 2014 Cut from 2 species of cedar, Yellow and Western Red Cedar. Pattern is a Steve Good pattern. Finished with shellac. DW Quote
smitty0312 Posted January 11, 2014 Report Posted January 11, 2014 Great looking basket DW.....looks very pretty. Thanks for sharing. Quote
Phantom Scroller Posted January 11, 2014 Report Posted January 11, 2014 DW are your after brownie points from the misses very nice box. Roly Quote
DWSUDEKUM Posted January 11, 2014 Author Report Posted January 11, 2014 Would be Roly if I had a misses. I just had the urge to make it is all DW Quote
Ron Johnson Posted January 11, 2014 Report Posted January 11, 2014 Hi DW Very beautiful , well cut and nicely finished. Quote
Phantom Scroller Posted January 11, 2014 Report Posted January 11, 2014 Would be Roly if I had a misses. I just had the urge to make it is all DW Still it a nice present for someone you might have in mind if you know what I mean. nudge nudge wink wink say no more. Roly Quote
frankorona Posted January 11, 2014 Report Posted January 11, 2014 Excellent work, a nice present for Valentine's Day, thanks for sharing. Quote
keefie Posted January 11, 2014 Report Posted January 11, 2014 very nice work DW, love the finish you always get on your work. Quote
jrpeteo Posted January 11, 2014 Report Posted January 11, 2014 Very nice basket. How do you glue the pieces together? I'm always afraid that I will have too much glue squeeze out, so the finish won't take. That's why I have not tried some of these. Do you put little dots of glue all the way around?? Pete Quote
DWSUDEKUM Posted January 11, 2014 Author Report Posted January 11, 2014 Very nice basket. How do you glue the pieces together? I'm always afraid that I will have too much glue squeeze out, so the finish won't take. That's why I have not tried some of these. Do you put little dots of glue all the way around?? Pete Pete for the most part that is what I do. I figure out where the rings ride and only put a dot of glue at each point. I then clean up as much as possible before the glue gets hardened. DW jrpeteo 1 Quote
LarryEA Posted January 11, 2014 Report Posted January 11, 2014 That is great. Love the way you 'pictured' them. A-n-d ... I use a toothpick and remove excess glue when it just starts to set...before it gets hard. It comes off very easy. (I'm speaking of TightbondIII) Larry Quote
coullion Posted January 12, 2014 Report Posted January 12, 2014 Another great box! Thanks for sharing. Quote
amazingkevin Posted January 12, 2014 Report Posted January 12, 2014 Dw if you ever open a store the name should be "What a Basket !" Quote
lawson56 Posted January 12, 2014 Report Posted January 12, 2014 That is one Beautiful Basket.I have tried cutting Cedar,Found it tough,must have been an old piece.Top Notch job. :thumbs: Quote
Luperez548 Posted January 14, 2014 Report Posted January 14, 2014 I can see your started working on Valentine's Quote
