bluelucky Posted July 1, 2009 Report Posted July 1, 2009 I just started making puzzles and want any advice I can get on placing photo's on and calenders. thanks Michael www.luckyscustomscrolling.com Quote
Travis Posted July 1, 2009 Report Posted July 1, 2009 Are you looking for mounting ideas to get your picture attached to the wood? I use spray adhesive on both the wood and picture and attach them immediately. I use an old credit card to really press in the picture and remove any air bubbles. Each spray adhesive is a bit different, so I'd read on the back for the best way to get a permanent bond. Carter Johnson uses regular glue, but I find it bubbles the picture. But it works well for him. I've also seen a lady on YouTube who uses clear polycrilic. She puts on a coat, attaches the pic, then puts another coat. I tried that and my picture curled, but I do like the idea behind it. I'll probably play with it a bit more in the future. Quote
bluelucky Posted July 2, 2009 Author Report Posted July 2, 2009 Travis , thanks for that info, I was also wandering if you put a finish on them or not? Quote
Travis Posted July 4, 2009 Report Posted July 4, 2009 Ahhh...I goch-cha. I misread your post. You can add a finish before you begin cutting if you want. I don't think most people do, though. If you're doing photos and calenders, I wouldn't worry too much about it. They're sturdy enough without the finish and hold up well with use. That's my approach anyway. Quote
