Been a sick lately, and the garage is just too cold to cut anything.   When it's 6 degrees out, the garage is only 38 degrees.  I just can't see spending a ton of money on kerosene to heat it during the winter.  I'm hoping I can start getting back out there middle of March..
I know the feeling; used to have only a tin shed in ND! to work in.
Worked some with insulated gloves and coveralls!  Just not a good type of situation.
Eventually spring will arrive.
Hi Kris good to know your up and running, well not running but up and around the house at least you calling in to let us know your still ticking.
Your right it appears where ever you are the weather is atrocious, so roll on nice spring sunshine.
Look after yourself God Bless.
Roly
