kohr349 Posted January 19, 2014 Report Posted January 19, 2014 i just received a craftsman scroll saw it is an older model 5722470, it uses a pin blade, i am looking for a spiral blade for this model, does anyone know where i can order one or how to modify the blade or machine to accept the plain blades. i have checked on amazon, and ace hardware and on the craftman website. also i am in need of a manuel. does anyone have an idea Quote
amazingkevin Posted January 20, 2014 Report Posted January 20, 2014 probably what you'll have to do is but another blade holder for a craftsman and modifie it to fit yours Quote
LarryEA Posted January 20, 2014 Report Posted January 20, 2014 Stephanie, Try contacting Mikes Workshop and Sloans Wood Shop. They sell blades and will know about the spiral end. I would also pose the question to them where you can get an adapter to convert to non-pin Look them up and I sugest you phone them. Both are friendly and may be able to give you a solution. I'll say a prayer you get a favorable answer and solution Larry Quote
LarryEA Posted January 20, 2014 Report Posted January 20, 2014 (edited) Do a search with this... " Adapt pin blade scroll saw to non pin " Here is one I got :www.olsonsaw.net/ac49610.html - Similar to Scroll Saw Conversion Kit - Olson SawThis kit converts most 16in. scroll saws to accept both plain end and pin end blades! Easy to Install. Designed for use on these 16in. scroll saws: Sears ......... Edited January 21, 2014 by LarryEA Quote
