Clockman Posted July 7, 2009 Report Posted July 7, 2009 Just wanted to show you all that yes my patterns can be cut. I worked on my Jesus Carrying the Cross (Cropped version this past week). It was cut entirely with a # 1 spiral. The pattern is very stable with only a few areas that I needed to be a little careful (only a little) I printed it to fit almost all of an 11x14 piece of 1/4" Cherry ply stacked with a 1/8" piece of popular ply. Total number of cuts was approx 390. Both pieces seemed very stable while cleaning up and removing the pattern and tape etc. Here is a photo of the Cherry one. Not framed yet. Had to reduce the picture size to upload so hopefully you can see the details. [attachment=0]jesus-cross - Copy.JPG[/attachment] Mike Quote
britetomro Posted July 7, 2009 Report Posted July 7, 2009 Mike, A really great cutting. A large number of cuts at 390. I like all of the detail and will have to put this one on my cut list for the not too distant future. I have always used #2 spirals. It looks as if you gave great success with this blade. Any concerns needed in preparation of using these blades. Thanks for the pattern as well. I've taken on some challenging projects before and look forward to getting into this one. Ron Quote
Clockman Posted July 7, 2009 Author Report Posted July 7, 2009 Mike, A really great cutting. A large number of cuts at 390. I like all of the detail and will have to put this one on my cut list for the not too distant future. I have always used #2 spirals. It looks as if you gave great success with this blade. Any concerns needed in preparation of using these blades. Thanks for the pattern as well. I've taken on some challenging projects before and look forward to getting into this one. Ron Ron, I have been using FD blades New spiral and like them a lot. One of the best thing I like to do when cutting with them is to use them also as a power rasp. With good blade tension and workpiece control you can fine tune your cut and fix minor oops that happen when you loose concentration or get momentarilly sidetrack while cutting. ( I use only my finger tips to direct my work piece as I find it reduces excessive pressure or side to side movement.). No special Blade prep other then using the recommended bit size for the holes, which sometimes requires a little extra effort to insert the blade. I recommend only top feeding on patterns of this magnitutde as finding the hole bottom feeding would be nearly impossible. I also tried spiral reverse blades on half of this cutting although the performance was not as good as the new spiral they did ok and did reduce the amount of fuzzies on the back, but I still prefer the FD new spiral of all spiral I have tried. Like I said 95% or better of this pattern is very stable, normally I tape all of my cutouts back in but did not tape any in for this. Mike Quote
mrsaw Posted July 7, 2009 Report Posted July 7, 2009 mike that is very impressive,love the detail.great job.tom Quote
Christina Posted July 7, 2009 Report Posted July 7, 2009 Absolutely beautiful cutting Mike. I love the new spirals too..........especially the #1. I use it almost exclusively. I love how detailed this cutting is..........great job on it and your pattern too. Thanks so much for sharing it with us. Christina Quote
Clockman Posted July 8, 2009 Author Report Posted July 8, 2009 Thank you for the great comments. Mike Quote
Travis Posted July 8, 2009 Report Posted July 8, 2009 Absolutely beautiful! Amazing detail, wonderful subject. You did a great job on it. I have a few of your patterns in my cut list I look forward to cutting. Be sure to put a copy in your User's Gallery. That is certainly something to be proud of. Nicely done! Quote
shadylady0447 Posted July 18, 2009 Report Posted July 18, 2009 What a challenge Mike! You really did a nice job on both the pattern and the cutting. Quote
