Dennis Key Posted March 3, 2014 Report Posted March 3, 2014 I am wanting to start scrolling a few portraits. I was wanting to know if there are any tips anybody might could give me before I start I have seen several Pictures of Jesus that I would love to do Quote
Ron Johnson Posted March 3, 2014 Report Posted March 3, 2014 Good day Dennis If you go to the forum and scroll down to finishing stress you'll find a few members reviews that may be of help. Others I'm sure will chime in with additional tips which will pop more questions in your mind. Quote
LarryEA Posted March 3, 2014 Report Posted March 3, 2014 Start with a less complicated one. Make sure ther are sufficient anchors or bridges to hold the work together. Sometimes a work becomes too delicate because you did not study the portrait pattern and plan for proper supports as you cut. Two cuts too close together leaving a piece in crisis of falling out. Look where you will end up at the end of a cut and do that before and during your cut. Larry Quote
Sparkey Posted March 3, 2014 Report Posted March 3, 2014 Start in the middle and work your way out. When cutting a new cut, cut the side closest to one already cut or you will make a weak spot that could break. I normally cut the small fine detailed stuff first and larger parts last. LarryEA and amazingkevin 2 Quote
amazingkevin Posted March 4, 2014 Report Posted March 4, 2014 Do the eyes first if they don't get cut right the portrait is useless,They are delicate cutting.you could hide most other mistakes but not the eyes! Wilson's Woodworking 1 Quote
Dennis Key Posted March 4, 2014 Author Report Posted March 4, 2014 thanks for the tips and the willingness to help the new guy I appreciate all you all have said .... Kevin I draw and if you don't get the eyes right it will take away from the picture I have thrown away pictures because I couldn't get the eyes right so I understand what you are saying. Quote
spirithorse Posted March 4, 2014 Report Posted March 4, 2014 I would suggest using the largest blade that can be used for the complexity of the pattern so that you have more control. Even if I only need one cutting, I still usually stack cut if using 1/8" material for the same reason (more control). Have fun and God Bless! Spirithorse Quote
Phantom Scroller Posted March 4, 2014 Report Posted March 4, 2014 Don't rush it it's not a race. wax to top of the table & learn to swivel the work on the table and into tight corners and out again. practice,practice and practice again. Roly Quote
bgloyn Posted March 4, 2014 Report Posted March 4, 2014 As others have said study the pattern and plan your cuts. I will sometimes scotch tape the cut outs in place for support a tip from another scroller. Take your time and things usually work out. Good luck. Quote
Lucky2 Posted March 5, 2014 Report Posted March 5, 2014 Dennis, I've always started out on what would be the hardest or most difficult portion of the pattern first. After that I would cut the eyes, of course that is, if they weren't already the hardest part. When I'm done cutting these two areas, I'll usually cut from the center outwards. Len Quote
ubgoofy2003 Posted March 7, 2014 Report Posted March 7, 2014 I agree with Len on doing the most difficult first & then work the rest of the pattern accordingly. I always feel that if I do the most difficult first & make a mistake, then I don't have a lot of time invested in an unfinished piece. Just try what you feel you can do. Confidence is a great partner with doing your first works of Art. Good Luck & enjoy scrolling. Quote
