Working ,consentration on all the details of a project ,things start to change so gradually and slightly that no actual problem is detected ,work continues ,interuptions breaks etc. pretty soon your having a condition you start working around that you never had before .Still a nuisance more than a problem ,before long it is a problem but happened so gradually it's hard to find ,such was the rescent issue with the clamping distortion of the blades I had . Clipping the blade helped ,but the hidden disconnected tip was the culprit ,Replaced the offenders ,and everything straightened out again .The point is some times this gradual progression is harder to find and fix ,and can lead you down the wrong path several times trying to locate the source .Breakage and stoppage are easy to identify if not easy to fix. Everybodies input helped me find and cure the problem ,Thanks!
