Your going to have more fun than a barrel of monkeys here.Welcome to your new home.here happy to set you straight and save you frustration of not knowing  WHY of all the problems you'll run across scrolling.We've been there done that so you don't have to ! We'll get you set up so scrolling will me effort less and more enjoyable.I angle the back of my scroll saw 12" up so i can see where the blade is more easaly.Get a foot pedal on-off switch to turn you saw on an off.Do your self a favor and come back offen to see what you'll have missed.Welcome again :)
You have found a great place!
BIG Hi-HO!
Among us we have really surpassed the level of screw-ups of anyone individual will ever be capable of. Most of us will admit that and help you avoid the same pitfalls. We do not think there are "dumb questions" sometimes we will give "dumb-answers-- not often and not deliberately!
Also remember that you are going to miss the line sometimes. AIM for the waste areas, easier to fix.
Also what works for one dose not necessarily work for you! Make your saw station fit YOU! Lighting seating angle all set your way.
Many patterns and pattern help easily available!
A $100 saw can make as nice of things as the $2GRAND one; tool SNOBS are still SNOBS! DO NOT LET THEM INTIMIDATE YOU! The cheapies can be great tools. Use what you have and only change to suit yourself!
Hi Ken ,Go with the blade ,any blade will only cut so fast ,let it do it"s work ,go slow , steady,& easy ,every blade is the boss! follow that and you will be amazed at what you can do ! You are just the Blade guider ,all forcing of any kind is your worst enemy .Control ,control ,control ,thats all there is to it  anything else is just politically correct B.S. ! welcome ,Best advice I can give to a newbee ,lecture over ,Welcome !!     As the little fellow said (It  ain't what you got It's how you can use it !)
Edited by Multifasited
Well, said..  slow, easy, the blade makes the difference.
Welcome aboard, Ken.
    It looks like you are not afraid to "go for it". gears are a great practice item too because they switch directions a lot. Are you making a wooden gear clock or just trying things out ? The key to enjoying this sight is to log on often. That way you find you will fit in quickly and get to know who we are, We all like that too, because we become familiar with you as well..No Ken, not that kind of familiar......anyway explore, respond and post..Glad you found us
Dick
heppnerguy
Hi Ken, welcome to the Village.  I'm Marg from Australia.  We have a great bunch of people here so if you ask any questions you are bound to get lots of answers.
Marg
Dick
heppnerguy
Figure the worse I can do is have to start over on another piece of wood so why not jump in with boith feet. I'm going to try a wooden gear clock, they look intriguing. But I’m  going to do some other things first to get more used to making tight turns and cutting straight lines.  I’m starting out with a Harbor Fright Special saw and Flying Dutchman – Ultra Reverse #5 blades to start out.
Ken,
   I have seen the saw but I have never used it. I might suggest that you pick up some   #3 ultra reverse blades too, if you plan to cut anything thinner than 1/2 inch wood. I like to us a double tooth blade #3 or #2 for thin pieces pieces with small delicate cuts because they are not as aggresive and much easier to control...at least for me.. Keep up the good work, I love your efforts.
Dick
heppnerguy
All ready retiring the Harbor Fright Special, guy next door is moving and gave me an old craftsman. Pinless blade changes are much easier. need to make a hold down foot for it, I get material chatter once in a while, and a nozzel for the air blower.
http://pozsgaidesigns.com/
The link above is to a good source of scrollsaw blades and even advice.
He gives good service and very good pricing.
Frank is also a very easy person to like. I had found his site on the internet, realized it was close so, I went ot see him.
Turned out I knew him from the local ACE hardware store.
He will treat you right!
Wood chatter often can be caused by a blade being put in with the teeth pointing up instead of down.. always check that out if it seems to happen very much in a row. Even after checking the direction of the teeth, I have still put them in wrong, sometimes
Dick
heppnerguy
When this happens ,the fuzzies will be appearant on the top of the cut ,you may not actually see the fuzzies ,but you will see a difference as the saw dust will start to clink at the cut edge ,and not have the sharp contrast and clean cut ,showing ! I have cut this way when down to my last blades of that size to be able to finish a project (getting double life out of a blade ,)it works OK and works in a jam ,but I would not reccomend it ! Extra work not much cost savings ,when you by your blades in bulk .
