How do you guys use a portrait frame? Using an 8x10, Do you take out the glass or make a deeper frame? I used a reg. frame I got from the dollar store. I used 1/4" BB. Not finished yet but I'll upload when I do. Thanks-
I have just started using frames and I too  believe it is worth a buck or two and makes the work much nicer. I buy mine from garage sales and the Dollar Tree, I really do not need to add any costs to my work to invest only $1 or less to set it off.
Dick
heppnerguy
I do both with and without and buy most of my frames for a store out in the Forest of Dean Gloucestershire for a couple of £3-5 each depending on the look and if they don't fit after taking out the glass I make my own and now I have loads of sheets of  8 x 12 glass sheets in the workshop. oops.  Roly
I get my frames from the Dollar Store. Here is an example of one of the frames.
I cut the wood to fit in the inside black plastic piece and I paint the backer that comes with the frame black.
  • 1 year later...
I ran across a aid to this problem ,I talked to a friend at hobby lobby ,and those clear cylinders they display their artifical flowers in are mylar ,I had her ask her if I could buy some new ones .I think they said .25 ea. I 30 of them I replace the glass with pc,won't shatter when dropped and very thin and savers space Holds up well ! I thought I'd pass it along fo the glass users!Carl
I too make my own frames. This way I can control the look of the finished project and by making the frame to fit the portrait, I don't have to worry about sizing the portrait to fit the frame.
I prefer simplicity over a fancy frame, just enough to set the portrait off.
Here is a Charles Dearing pattern done on 1/8" oak plywood with a stained Baltic birch backer, framed in a 5/8" thick Mahogany frame with no glass. The frame is built around the portrait, all glued together so the frame is not removable and does not require any reinforcements at the corners.post-23695-0-95298100-1432441243_thumb.jpg
I buy my frames at garage sales( if I can find decent frames) also I buy them at church rummage sales.Useally at 50 cent a frame but never over 75 cents. ( if thay are decent frames) I now have 10 frames ready for pictures.
