As my son is getting used to the new DW788 that arrived today, we noticed a small issue with blade tracking. Looking from the side there is almost .060" movement in the blade from top to bottom of the stroke. On my EX I could loosen the motor mount, rotate the motor slightly, and correct the issue.
Any suggestions that don't involve changing holes to slots on the arm mounts?
Edited by dansnow
Hi Dan,  I ran into the same problem/s that you did.  First I had the blade tracking problem as you do, then I was told to go to Ricks scrollsaw ;post.  That had me puzzled for a while because I was looking on the SSV site here.   -  However thanks to Doug, - he put me on to the site which is here;  http://www.scrollsaws.com/
Go there, and you will find such a wealth of information that you will have to scroll down quite a bit to find the blade tracking article.
You will enjoy all the information there, I think.
Cheers,
Ed
Since you edited you post ,,Micro adjust your table ! This is not a main stream idea or is it probabaly seriously thought of as a fix ,However .there is more than one way to skin a cat ! You just need to want a skined cat ! Mine is skinned !
Edited by Multifasited
