Hi all
I have a program and no one has talked about it.  Please coment on it as I am not a expert at all.  Serif Draw Plus X5.
Thanks Barbara
Hi barbara,if you google serifdraw plus x5 tutorials you'll find quite a lot of videos for it. I'm not a computer buff but the videos might help you. Have a good day.
Rob Roy.
Looks like a good program.  The thing with graphics programs is that they are more-or-less the same, in concept anyway.  The difference is where the buttons are located and sometimes what the buttons are called.  You can go through the Inkscape Class and get a feel for the designing process, then look for some tutorials specifically for Serif Draw Plus X5 to learn the interface.
There is a free 2d cad software called Draft Sight. It does everything Autocad will do. I insert raster images a lot and trace with lines and arcs. I use Autocad at work daily so a good freebie for me.
